gearing with the 520 chain?
Old 03-06-2006, 04:27 PM
SANDMAN430's Avatar
Default gearing with the 520 chain?
does the rotating mass change cause any gear changing? for our dunes 15-42 was pretty nice on the 530.
Old 03-06-2006, 04:36 PM
DSNUT's Avatar
Nope. Gearing is only effected by circumferencial leverage. You could theoretically reduce rotational mass enough that you would benefit by running a little higher gears. That is possible.[img]i/expressions/face-icon-small-wink.gif[/img]
Old 03-06-2006, 05:07 PM
yjacket2001's Avatar
Sandman,
How much for TVI-720 and what did you get? Do they resleave or new (AL?) cylinders? What cylinder coating material, Nickel? and what other components in package?
I don't see anything on TVI site, so they may not still produce them-?
Thanks a lot!
Old 03-06-2006, 08:28 PM
ERBEDS650's Avatar
The TVI is a Steel sleeve and Gary says its not a LA sleeve he said he orders them from some company that makes sleeves for race cars he dosent coat his cylinders, my Aluminum sleeved cylinder that was nikisiled is a 730 yep the piston was 105.5MM woohoo will be in this week Ill take picks when it shows up this week, waiting on other componets before I rebuild the top end.
Old 03-06-2006, 08:44 PM
SANDMAN430's Avatar
seems like mine was 1200, a few years ago.
Old 03-06-2006, 08:59 PM
Thanks Guys for the information.
ERBE,
Where did you get nickeled at and how much? That sounds like the best cylinder wall surface available for longetivity.
If I go into my engine, that would be an extra nice addition for the trouble.
Thanks
Old 03-06-2006, 09:50 PM
ERBEDS650's Avatar
Heres the link, they charged me 400 for the bore sleeve and coating, but they dont sel the piston, you need to send them a piston so they can match fit it to the clearence required. Text Millennium Technoligies Ask for Kurt.
Old 03-06-2006, 09:52 PM
Excellent! Thanks ERBE
Old 03-06-2006, 09:55 PM
SANDMAN430's Avatar
for 400 is the sleeve installed in the cylinder?
Old 03-06-2006, 09:58 PM
ERBEDS650's Avatar
Yep for 400 bored, new sleeve, installed, coated and honed to match the cylinder, BTW Oldman racing is the one who turned me on to these guys!
Quick Reply: gearing with the 520 chain?
