powder coating the frame
Old Mar 10, 2006 | 10:49 AM
SANDMAN430's Avatar
Default powder coating the frame
hey i'm having my frame powder coated, dressing up the machine a little,other than getting the coils grounded to bare metal is there anything else to be aware of?
Old Mar 10, 2006 | 11:57 AM
FatHolly's Avatar
You also need clean metal for the ground strap off of the battery.
Old Mar 10, 2006 | 01:38 PM
bombdsbaja's Avatar
AZSAND made it clear that a lot of electrical problms can arise if you don't make sure that there is a good ground between the sub-frame and main frame. Mine will be going in for powder coat in the next month....what color are you getting????
Old Mar 10, 2006 | 02:22 PM
SANDMAN430's Avatar
kind of a copper-red metal flake i think,
Old Mar 10, 2006 | 04:07 PM
Majorecho's Avatar
make sure you protect as many bolt holes as you can, the guy who sprayed mine put it on so thick that even the a-arms, sub frame and swing arm where hard to get back on. I did a lot of drilling and prepping before I even tried to assemble the thing
Old Mar 10, 2006 | 05:33 PM
BigDaddy331's Avatar
What are we looking at cost-wise to powdercoat the frame and sub?
No motor right now, so it might be the perfect time to do it. We were going to start powder coating ourselves but have yest to build the oven.
Old Mar 10, 2006 | 06:03 PM
sandbomber's Avatar
160 to 180 Mike
Old Mar 10, 2006 | 06:42 PM
Thanks Bomber...
Been calling around here, and I called what must have been the most expensive place around. They quoted me around 475. Called a couple of others and I was told 175 - 250. Not too bad I guess. The question now becomes - should I powder coat my a-arms (stock)? I'm not worring about saving the pounds, and I don't wan't anything wider..... don't really want to pay big bucks for new ones either.
Thoughts????
Old Mar 10, 2006 | 09:35 PM
SANDMAN430's Avatar
150 to start other colors vary the price.
Old Mar 10, 2006 | 09:38 PM
Majorecho's Avatar
does the $150 include sand blasting? IF so I got raked over the coals, I was into mine for about $400- did an excellent job, 2 coats of powder and a clear coat.
