ds caught on fire
Old Apr 6, 2006 | 12:11 AM
  #21
Sparky8370's Avatar
Default ds caught on fire
I don't think you'd have screwed anything up at this point. I hydra-locked a CAT 3208 with coolant, the head gasket blew, and ended up "hop-starting" the truck. Since the cylinder was completely full of coolant, and it was a diesel (really high compression), when I forced it to start it bent a connecting rod.
Old Apr 6, 2006 | 12:15 AM
  #22
pugads650's Avatar
well my bike starts perfectly so i dont think i bent a rod but is it neccasary to change the oil 2 times every time i change the oil its like 45.00 bucks
Old Apr 6, 2006 | 12:22 AM
  #23
DSNUT's Avatar
The oil rings won't hold the gas in the cylinder. It will go right past them and dilute your oil. You need to either change it a couple times or do an unbelievable job of purging your motor of the contaminated oil or you could have premature engine/tranny failure.
I have spent hundreds of dollars on screwups. Education costs money no matter where you get it, just make sure you get something for your investment.....[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 6, 2006 | 12:28 AM
  #24
Sparky8370's Avatar
Yeah, what he said. You don't have to do that every time. Just now, as a remedy for your error.
Old Apr 6, 2006 | 03:10 AM
  #25
BlackHawk's Avatar
Since you are purging your oil system of gasoline, why not use a cheaper oil during the purging process? You wont be running the engine much on each change of oil. Either way, even if you spent $90 on oil changes - it is still a hell of a lot cheaper than a rebuild any day of the week, right?
What kinda oil are you using that costs you $45 per change? I use some semi-synthetic from Bel Rey & I think ti was $45 or so shipped to my door for a case of it.
Old Apr 6, 2006 | 01:03 PM
  #26
pugads650's Avatar
i use brp oil for the ds 650 and brp filter i think they are 7.99 a quart and the filter is like 13.99 i just remeber the last time i changed the oil it came out to about that i buy my stuff at berts mega mall
Old Apr 6, 2006 | 01:28 PM
  #27
DragonDJ11's Avatar
That sounds about right, but now times that times 3 for us. Ouch
Glad you survived this event to learn....Good luck
Old Apr 6, 2006 | 07:03 PM
  #28
VEGAS650's Avatar
while your at it, get a stainless steel oil filter.
About $80 but you'll never have to buy another one.
There are alot of good oils out there that don't cost that much either.
do a search and you will find out what most everyone is running.
I was using Amsoil 0-40 at about $5.50/ qt.
ultangler
Nov 30, 2024 01:35 AM
mrtidy
Feb 3, 2016 05:00 PM
IMLN
Sep 28, 2015 03:32 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
