IMS Pegs and Guards Install
Old Apr 17, 2006 | 12:44 AM
ERBEDS650's Avatar
Default IMS Pegs and Guards Install
Pegs are great went on perfect, But....................................them fricken Aluminum Guards Fricken ticked me offya gotta re bend them to fit and tug on the fenders and the gaurd is now too close to the pipe I ghave to readjust the fricken pipe. But..........parts look good! LOL
(Venting on these venders making highdollar parts that dont jig up during assembly) Take notes IMS!!!!
Old Apr 17, 2006 | 01:08 AM
FatHolly's Avatar
Everyone I have read about who has the IMS heal guards has had the same problem... sucks cause I heard they would be sweet if they fit right... nice that you were able to bend them up right. Don't worry though IMS is not the only company putting out products that don't fit right... my AC Racing Pro Peg Nerfs came with peg brackets that were in no way even close to working... I had to weld up my own. The ones I made are 100% stronger than the AC's... they were really thin folded sheet metal... mine are 1/4 inch wall steel tubing. I figured peg strength was pretty important when you weight 350lbs... I guess AC didn't feel the same way.
Old Apr 17, 2006 | 01:13 AM
ERBEDS650's Avatar
Thats why I went with IMS for us Economy Sized riders[img]i/expressions/face-icon-small-smile.gif[/img] Wooho I also got my work shocks from E-Bay, getting them Re valeved tomorrow (Friend is doing it) and ordering Eibach springs in the morning.
Old Apr 17, 2006 | 06:00 PM
JSsDS's Avatar
I bought one of the first set of heel guards from IMS and I gotta tell you it was a nightmere. After waiting several months for them and being consistantly lied to by their customer service rep, I finally received a set. The right one fit fine but the left one appreared to be made for some other brand of quad. I had to cut, rebend and have a friend TIG them back together. I got my money back and got to keep the heel guards as well but the whole ordeal was was the pitts.
At the time I was buying them, AC was making them for IMS-Roll. Not sure if that is still the case but it sure sounds like it.
Old Apr 17, 2006 | 06:12 PM
ILivSD's Avatar
Interesting [img]i/expressions/face-icon-small-confused.gif[/img]
as my set bolted right up to the frame,(kept the screw loose) used a little floor jack popped them right on in less than 15min give or take a beer or two.
Look great and beefy... man my boots stick to the Pegs like smelly glue... some times a little to much. Great design as far as pegs go.
Kind of pricy but then what isnt for the DS
But happy none the less. That was a great MOD...
Old Apr 17, 2006 | 10:42 PM
Entomber's Avatar
ERBEDS650
Is that the newer style heel guard? Anyway to see a pic of your new setup? I have thier foot pegs (which are sweet btw) but at a dilema on the heel guards.
Old Apr 18, 2006 | 06:22 AM
jakeds650's Avatar
i have also had problems with the heel guards i have gone through two pairs of them on my ds, and now have the third set on. luckily ims and roll design have been cool enough to exchange them for free. but this last time they told me that they probably weren't going to make them anymore due to the fact that ac racing made the heel guards for them. one thing to look at is the bend where they bend up to connect to the pegs, they seem to always start cracking right there, you guys should check yours out.
Old Apr 18, 2006 | 06:23 PM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
The IMS heel guards are a bit on the whimpy side, sooo that is why i modified mine & strengthened them up . if a person weighs over 100# they will not last. the best way to fix this is too add a piece of 1/2 in bar stock to the back side of the inner down bar, or replace with 3/4in, and across the bottom that will solve the weekness. I "fixed" mine before i ever installed them, & they will work with stock pegs. if you check my pics you can see the mods i did to mine.
Old Apr 20, 2006 | 09:11 PM
ERBEDS650's Avatar
Got em on , had to grind the corner to miss the pipe, you gotta look for it thou, I was lucky to have a bending break at my shop to bend the dang things correctly.........she looks good, getting my springs this friday for the shocks, and start looking for some Spring Under buckets and put that 720 on.
Old Apr 22, 2006 | 01:44 AM
SandyBear's Avatar
Love my pegs. But they (IMS) sent me two right side pegs first. Then when I got the heel guards, they came without the hardware and the finish was scratched from poor packaging and the welds were sloppy. One black splatter mark from sloppy welding was in the smooth flat surface of the heelguard itself, nowhere near the welds and it was not even cleaned up. My last complaint was with the holes lining up on the pegs themselves.
I spent a long time modifying the stock DSX nerfs to fit that combination, but after all the other time I spent on getting it right, it was worth it and it looks sweet and like they were made to fit (to my credit).
For the reason of the high cost of the IMS product, I opted against going IMS again for the new LTR450. If I spend that much $$$, I dont want to have problems and want it right the first time or make it right quickly. And a little better on the customer service end too!
If IMS is paying attention, you lost a return sale.
Bear[img]i/expressions/face-icon-small-disgusted.gif[/img]
