OK, OK, OK, I'm getting the Outy 800 2X Now what???
First, its all your fault. I coulda just got the kawi 750 bf... but no you talked me into this one.
So.. what shoud I do to it to make it even faster? As on a previous post I HATE the battery placement so I will get a fix and share it with everyone. But what is the top few things that extracate more power from this beast? I know the Kawai's fairly well but not this one. No I'm not doing NOS or anything on it just looking for a working mans tweak.
What worked for you and what did not work for you? I would appreciate any input.
Thank you.
Rob
Thank you.
Rob
I don't have anything on mine yet, but this is the results I have read from adding the dobeck and pipe,another thing I have read is is Chapman performance is developing cams combined with porting which develops around 58 horses to the ground check it out http://atv.dnsalias.com/forum.cgi?vi...r&viewtopic=88
dobeck is a fuel managemant programmable box for efi. i put it on my o6 outty 800 with better exhaust. i can feel the diff. its only good if you mod your ride. does nothing for stock because it only allows you to add fuel at diff points.
