need a little info
Old May 14, 2006 | 10:14 AM
dlog's Avatar
Default need a little info
i have a 2000 ds 650. i have no manual and there are no bombardier dealers in my area at all. i was wondering what weight oil it uses and i also might need to replace the clutch and was wondering if anyone knew of a good company to get one from. just a stock grade one, not looking for a high performance one. any info would be helpful. thanks
Old May 14, 2006 | 02:26 PM
rfwlll's Avatar
I now run that valvoline 4 stroke oil from auto zone. They offer 10w40 and 20w50. I use the 10w40 in the colder months and 20w50 in the warmer months. As far as a clutch goes, is it ***** out or just slippin a bit. Because if it is just slippin a bit you can install stiffer springs and whalla its as good as new. This is a ds issue and very common. I used the ron woods 60% stiffer than stock springs because my clutch would slip a little when i got it, it only seemed to slip when i was on the throttle hard and shifting to next gear. Do a shearch on clutch springs and you will find all the info needed. A clutch or spring change is very simple and you can do the clutch spring change for around $30 i think.
By the way if your gonna do a complete clutch change I would say use the barnett kit. Good luck and if you need anything else just ask. RUSS
Old May 20, 2006 | 09:34 PM
dlog's Avatar
i am going to take your advice and try the ron woods springs. sounds just like what mine was doing. thanks for all the helpful info
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
greg86hd
Sep 16, 2015 12:32 AM
