i need help.....
Old Jun 13, 2006 | 05:27 PM
Mitch101's Avatar
Default i need help.....
well i bought a 2000 ds650 about a month ago . and so far its been nothing but problems. not big problems. just alot of small ones. so heres my new problem.. my rear berrings started sqweaking and then it siezed but only for a bit. now i got it unstuck but it sounds likes theres sand it there. i attempted to removed my rear axel but i cant get the sprocket hub off. any tips on getting that damn hub off??????
Old Jun 13, 2006 | 06:11 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
make sure you take the snap rings off first that are holding it in place, mine was a pain, took my a long time to gently keep tapping it off, and even getting it on the new axle it took 30 mins of pounding to get it on. just be careful if you hammer it off, its cast and will shatter.
Old Jun 13, 2006 | 08:00 PM
Mitch101's Avatar
i did take the snap ring off. but im still having a real hard time
Old Jun 13, 2006 | 09:38 PM
sinch's Avatar
Block of wood and a hammer works.[img]i/expressions/face-icon-small-smile.gif[/img] Hit the block insted of the hub.
Old Jun 13, 2006 | 10:09 PM
Mitch101's Avatar
tryed that to ..... its stuck
Old Jun 13, 2006 | 10:23 PM
sinch's Avatar
pack the shaft in dry ice and the carefuly heat the hub. Good luck and that should work for you. If you can't find dry ice use regular ice.
Old Jun 13, 2006 | 10:27 PM
Mitch101's Avatar
thnx... im taking off the rear axel by removing the sprocket. am i doing it the right way . i think i am . am i?
Old Jun 13, 2006 | 10:33 PM
sinch's Avatar
No you have to pull the hub on the other side remove snap ring hub brake hub then slide axle out of bering housing. When you put the new berings on make sure you put them in the freezer for a day it will make it much eazyer to put on when your ready.
Old Jun 14, 2006 | 12:41 AM
Mitch101's Avatar
awsome. thnx
Old Nov 19, 2007 | 04:56 PM
spikedbat's Avatar
did you have any problems getting the brake hub off? I cant get mine off.
I'm stuck, i've removed the snap ring, but it almost looks like their is anothing snap ring on the inside of the hub, or perhaps an o-ring of some type, but its in the way, and wont let the brake hub slide over the part of the axle which flaires out.
Anybody know what i'm talking about, and how I get that oring or snap ring off?
