Air filter question for 800
Old Jun 20, 2006 | 01:28 PM
pads's Avatar
Default Air filter question for 800
Does anyone make an aftermarket foam filter for the Outlanders?
Second question: Went riding Sunday, very dusty. I replaced the air filter which cost $36. When I had a foam filter for the DS, I cleaned it after every ride. In dusty conditions, is this necessary on the Outlander.
Third question: The stock filter had no oil on the outer foam covering. When I put the new one on, I put a light layer of No Toil on it. Was this overkill or not?
Old Jun 20, 2006 | 01:46 PM
Cardiac's Avatar
You can take all the "shootouts" and put them in one bucket and you won't have beans.
I believe the owners manual tells you how to remove and 'clean' the cotton air filter that the outie comes with. You have to wash it, make sure it is dry and then oil the filter. The foam filter on the outside should remain dry. At least that is how I am reading the manual. It looks to me like the stock filter is a very good one.
Old Jun 20, 2006 | 07:18 PM
maxxedouty's Avatar
a light coat of oil is reccommed by my manual to the prefilter. apply oil to your rubber glove and then wipe it on the prefilter so as not to saturate the prefilter.
Old Jun 21, 2006 | 07:52 AM
pads's Avatar
Thanks for the replies, I'll have to look in the manual. I just assumed the filter was a paper element type and there was no maintenance.
Old Jun 27, 2006 | 01:44 AM
kawiyowee's Avatar
You can clean the foam prefilter every ride, but you don't need to. I just rode 400 miles in 4 days in dusty dry Utah and the oil tacked foam filter I had on it was not discolored at all next to the cotton filter - of course the outside was pretty dirty. Ran good the last part of the 400 miles too. Twin Air makes an after market filter, but I believe what you have is what is designed for the engine and is a plenty good enough filter. I have an extra filter set, cotton and tacked foam that I carry on longer trips. I changed the filters on the fourth day, but really didn't need it. Was running good, no dust in the intake pipe that the filter clamps to.
Ronk407NY
Feb 13, 2016 11:05 AM
Jenn1
Sep 8, 2015 09:16 AM
QuadCity
Aug 13, 2015 12:58 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
