Raditor
Old Jul 24, 2006 | 06:44 PM
BioWare's Avatar
Toxic Ryder
Default Raditor
Just wondering what raditor fluid on their ds650 the boys are usein. And whats the best to get. Should I go with a 50/50 mix or straight up lime green fluid. I have never replace my fluid before and the DS650 is a 2005. Just lookin for the best for the quad.
Old Jul 24, 2006 | 07:19 PM
bombrider04's Avatar
Default Raditor
I use any type of antifreeze I don't really think it matter the brand so much just the mixture I get the straight antifreeze and mix water with it. But I guess it depends on where you ride and climate wise.
Old Jul 24, 2006 | 07:28 PM
cynick's Avatar
Default Raditor
We use Engine Ice. I will give you an example why we spend the money for it. When My husband first got his bike the fan didn't work well it blew the radiator hose more than once and it sucked. Well we switched to Engine Ice before we got a new fan and it never blew the hose again and he ran it for about a year with out a fan. Needless to say it cools down the engine quite a bit. It also is good for cool temps also. We go from top to bottom here. As high as 105 and as low as -20 or more and never have a problem with starting or anything. Just my 2cents. I hope it helps.
Old Jul 24, 2006 | 09:08 PM
Scatterbrain's Avatar
Default Raditor
Straight engine ice. Its the chit!
Old Jul 25, 2006 | 10:28 AM
BioWare's Avatar
Toxic Ryder
Default Raditor
How much is engine ice. Where can i get some... Is it hard on the engine, is good for the DS, just asking question just don't want to damage anything .Thanks for the all the input..
Old Jul 25, 2006 | 12:28 PM
Default Raditor
Should be able to get it in just about any bike shop. Totally safe to run. It will lower temps as much as 20%. Price I think is around 20 bucks. No mixing, but you do have to flush your cooling system first before putting it in. (pretty easy really). Ive been running it all season and it makes a big difference temp wise. Fan hardly ever comes on.
Old Jul 25, 2006 | 12:37 PM
cynick's Avatar
Default Raditor
Just to add to that it is also biodegradable and non-toxic so it is safer if you leak it out or have to replace it. And you can get it for 15.49 for 64oz. from Rocky Mountain. O and it says it can reduce your engine heat by up to 50degrees.
Kenidah
Sep 7, 2015 07:50 PM
moddedscrambler
Apr 27, 2015 11:03 AM
AussieZilla
Jul 12, 2001 10:43 PM
flajimak
Jul 6, 2000 03:21 AM
