Stroker version???
Old Jul 28, 2006 | 04:02 PM
DSNUT's Avatar
Default Stroker version???
I will grant that the strokers are more work but isn't the RWR stage III about $4k for the kit? Aren't those also ranging between 55 and 60 hp? I have never thought of RWR as inexpensive when you consider the modest horsepower. I had way less than $4k into my 730 motor that was making 70 to 72 hp depending on the dyno....................but I still had to build a stroker[img]i/expressions/face-icon-small-smile.gif[/img]
Good luck!
Old Jul 28, 2006 | 09:39 PM
DuneMe's Avatar
Good catch Nut. . . side-tracked from phone calls.
Stage II + mild port work.
Head work on the Stage III is about $2,000 by itself. Get a $300 to $400 port job with the Stage II and you are good.
I agree that the 720/727/730 kits are a good set-up but, generally with those come most of the stuff on Stage II so you are into it for like you say. . . about $4k+
Pipe/carb/CDI/high compression piston/cams/valve springs/air filter = great power.
Anyways. . . what are YOU looking for more power for?
antiguogrumete
Sep 5, 2015 03:41 AM
black_thunder
Aug 19, 2015 03:23 AM
chammerbeck
Jul 17, 2015 08:06 AM
RedRancher
Jul 10, 2015 06:36 PM
