What is the max rpms on DS650
Old Oct 25, 2006 | 11:40 AM
  #21
maxxedouty's Avatar
Default What is the max rpms on DS650
If you race in the sand, thats all i do, then you need a little wheel spin,i can stick the nose pointing at the moon if i'm not carefull,thats why i'm going to a lonestar+4".
Old Oct 25, 2006 | 11:48 AM
  #22
DSNUT's Avatar
I assume this is on the banshee? Yep, sand is different for sure. Most of these guys further east haven't seen sand dunes. They run turf tires on harder surfaces more often then paddles I imagine.
You like the LoneStar the best? I haven't really looked at there products but I see them advertising everywhere.
Old Oct 25, 2006 | 12:03 PM
  #23
maxxedouty's Avatar
right, surface is the diff, in sand you want a little spin so when you hit the powerband and hookup your gone. i have rode ds before, but not an expert for sure. i could see maybe a couple of hun rpms or so past peak before shifting a ds. like you said due to the torque.
Old Oct 25, 2006 | 12:32 PM
  #24
maxxedouty's Avatar
my 800 has 77ftlbs of torque and it puts it down now, even in 4x4 with dune stars front and back i still spin on take off. i will be going with a set of paddles that are being made for the back of the 800, and keep the dune stars on the front to see if that helps.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bigtwin700
Sep 10, 2015 10:46 PM
Steeldon
Sep 9, 2015 09:38 AM
