Clutch Shaft on Clutch Cover... keep breaking them
Old 11-16-2006, 01:32 PM
Boomer84's Avatar
Default Clutch Shaft on Clutch Cover... keep breaking them
Replace both at same time new part # 420237023 shaft,420259203 rack-actuation,bad teeth on one will destory other.These are H/Duty replacements.
Old 11-16-2006, 01:45 PM
Entomber's Avatar
Thanks guys for your input. I already ordered a 2000 model part, but again if they break I will order the updated version of them. I will report when I have them, running or not.
Old 11-16-2006, 07:56 PM
Teebone56's Avatar
Just pulled both partsd out of my buddies bike, we are waiting on the long shaft. when we put the inner shaft togather it felt a little loose is that normal. By loose I mean there is play from side to side.
Old 11-16-2006, 09:56 PM
Entomber's Avatar
Teebone56
I suggest he replaces both parts. I think when one goes the other needs to be replaced. I did everything by the book and with care and I'm getting the same results.
  #15
Old 11-21-2006, 12:22 AM
Entomber's Avatar
Okay being sick all weekend didn't help but I pulled the clutch cover off again and found a possible suspect, the bearing where the accentuator goes thru was popped off. I didn't know how I didn' notice it before. The bearing looks fine. No scoring on the race area. The manual states to freeze the bearing and heat the pressure plate so I am doing that now. I wonder what caused it to push out. I also wonder if it will happen again. I got my parts in. Let's see if I can get it to work.
Anyone ever had this bearing pop off on them?
  #16
Old 11-24-2006, 10:46 PM
Entomber's Avatar
Bike seems to be up and running. With a 9 disc set up and stronger springs it hooks up big time (neutral seems harder to find). I don't think I will have any slipping clutch issues at all. It's been a while since I rode the DS so it feels new to me all over again. Thanks for the input guys looks like she will hold together (Riding it hard this Sunday).
  #17
Old 11-25-2006, 12:04 AM
Teebone56's Avatar
Replaced both parts and I am going out to try them tomorrow.
ghost civic
01-15-2020 07:43 AM
slowgsxr97
09-08-2015 04:37 AM
ghost civic
07-15-2015 10:48 PM
clsharky
07-13-2015 02:07 PM
200es
07-10-2015 09:09 AM
Quick Reply: Clutch Shaft on Clutch Cover... keep breaking them
