Brake uprgade question....
My '01 has had spongy front brakes for some time now with uneven braking (right wheel will lock up and left won't) so I've decided to finally do something about it, I suspect my master cylinder is at fault as I have bled until blue in the face, replaced pads, cleaned rotors and the lever simply squeezes all the way to the grip. Anyway I got a master cylinder from an '06 Hayabusa and plan to run two lines with a double bleeder banjo bolt. Do ya think that runing two lines will be of any significant benefit? Harder to bleed? Any comments?
oliveiracarlos
09-07-2015 03:39 AM
