Engine tear down DS650??
Old Nov 25, 2006 | 02:34 PM
baja02's Avatar
Default Engine tear down DS650??
Budget:2500$
I was wondering about how many hours would it take to pull a motor out of a DS650, split the case and replace all the engine gaskets. My DS is spiting oil quite bad.
With a 2500$ budget what should i do while the engine is out and split?
(crank bearings are solid)
Would a Ron Woods Stage 2 kit a good idea, is it worth it for the money? And would it drop my reliability?
Thanks guys
Old Nov 27, 2006 | 09:40 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
A weekend is plenty of time if you have all of your parts on hand. be sure to get a service manual it is VERY helpful if this is your first time. bikebandit.com has all of your oem parts and they have exploded views of the motor so you can get just the parts you need. as far as performance... yes the machine will be faster, reliability is a lways an issue with performance... can you fix it when it breaks & how much will it cost? just my 2 cents.
Old Nov 27, 2006 | 12:50 PM
DuneMe's Avatar
Spitting quite a bit of oil???
Where is the oil coming from? Starter housing? (If so, no reason to tear apart your engine. . . it isn't going to help.
I like the RW Stage 2 kit (or similar by another builder.) The biggest reliability issue you'll have to deal with will be the valve springs. You'll have to put new valve springs in every couple years (or every year if you go to the real aggressive cams.)
What are you looking for power wise and what are you willing to do maint. wise.
I'ld suggest keep her as stock as possible. I'ld rather ride than work on my bikes.
Old Nov 27, 2006 | 04:24 PM
baja02's Avatar
the oil is coming out of the tranny case. i have already fixed a leak around the starter. i got to split the cases
Old Nov 27, 2006 | 11:10 PM
DuneMe's Avatar
Tranny case???
Where?
Is it coming out of the countersprocket? No need to split the cases if it is. Get a self tapping screw and drive that sucker into the bearing seal. Once it is in about 1/2 way get your cat's claw out and pull that sucker out. Push the new one in from the outside and your golden. I've done one before and worked like a champ. I'ld get two bearing seals though. First one didn't go in quiet straight so, I ended up pulling it out and putting a 2nd new one in. Unfortunately, had to drive across town to get a second seal.
Old Nov 27, 2006 | 11:32 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
2500 lets see 700.00 lte dual exhaust 250.00 lectron 46 (not the world famous 46hv just a 46 lectron) 350.00 Ron woods cdi 750.00 boss noss direct mount air filter 65.00 you will have a world class duner and a monster at the touch of a button.LIFE IS GOOD [img]i/expressions/face-icon-small-happy.gif[/img] And i did not do the math but i belive were under budget you owe me dinner[img]i/expressions/face-icon-small-happy.gif[/img]
Wait the filter comes with the exhaust so take the extra and spring for the vortex cdi you owe me buddy.....I drink MGD
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Jul 30, 2015 09:39 AM
vlkster
Jul 28, 2015 11:35 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
