In the Sand....
Old Nov 28, 2006 | 11:00 PM
  #21
MrMeaner's Avatar
Default In the Sand....
2500 will get you alot more than beating piped and jetted. Oh yea a CDI, carb, porting and valves, piston and cams. Your ready for most out there
Old Nov 29, 2006 | 12:16 AM
  #22
DSNUT's Avatar
lol, what is alot on the race hills in Oregon? The hills are short enough here that the DS has to overcome its own weight with a lot of extra power since the hole shot is so important. On longer hills the hole shot isn't near as critical. I ran a stock bore DS before I met HPR that was about 60 hp and I was about dead even with piped YFZ450's and piped Banshee's. I would gain on the face but only to make up getting out of the hole slower. My build was similar to the following with the exception of the piston, which was a TVI that was much more expensive and the carb. I had a Lectron 46. I didn't have NOS either but it seemed like an appropriate upgrade if he wants to run with the Banshee's that are actually marginally quick, lol.
Pipe - $250
paddles - $300
+4 swingarm - $450
longer brake line - $30
Chain & Sprockets - $120
Web 109 Cams - $250
Shim under kit - $350
12:1 Piston - $160
Ported intake - $90
Head Porting - $600
1mm oversized valves - $175
Seats & Valve job - $180
2 Valve guides - $30
Hardened Head studs - $40
Head Gasket - $30
TM45 - $350
NOS system Installed - $1000
Oil & Filter - $30
Coolant - $10
Total parts: $4,445 (Will you do the labor yourself, or do you hire that out?........if hired add about $500)
Which parts would you guys pull out to get the budget down to $2500 without costing yourselves enough horsepower to lose to that Banshee on a steep hill?[img]i/expressions/face-icon-small-happy.gif[/img]
Something else, my stock bore DS did much worse against 450's at St. A's than it did in Oregon. The reason was the elevation. It made the extra DS weight an even bigger problem since hp was down 15% or so at 5000 ft. The YFZ only lost about 6hp, I lost double digits........weight obviously remained unchanged.
Now if you really want a DS to rip..............naw, too much info for one night. Maybe another time, lol[img]i/expressions/face-icon-small-smile.gif[/img]
Which do you ride more, Oregon dunes or St. A's?
Old Nov 29, 2006 | 12:31 AM
  #23
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
AHKN
Old Nov 29, 2006 | 12:43 AM
  #24
ERBEDS650's Avatar
Dont get me wrong I love the DS its a fun toy but you need to drop allot of coin to make lighter faster stronger and there are some amazingly fast stock bores and big bores out there, but for hill racing, speed, light weight and cheap HP go 2 stroke.
you can pick up at some great prices Banshee, Quadzilla, CR500 in a fourtrax aftermarket frame, convert it to alcohol on hang on!!!
I have a zilla making close to 78 HP just ported , carb, pipe, and a cut and rechambered head on 110 gas, my buddies Banshee is making close to 100 HP on alcohol.
Just my thoughts ERBE.
Old Nov 29, 2006 | 12:56 AM
  #25
cynick's Avatar
He wants to beat a banshee, not just be another one. Plus he asked about the DS, not that there's anything wrong with the rest, he just wants to be different like the rest of us.
Old Nov 29, 2006 | 01:16 AM
  #26
ERBEDS650's Avatar
Yeah it is fun being the red headed stepchild of the Quad world!
see if that dang turbo efi system was 2500 bucks instead of 4000 theres an easy 80 HP -
Erbe writes dear Santa could you drop that off for me i have been a good boy this year or ill take Playboy playmate im easy .
  #27
MrMeaner's Avatar
WOW nut you got it going on
AHKN
Old Nov 29, 2006 | 01:24 AM
  #28
duneittilludie's Avatar
It is true that 2500 will get you a fast DS if spent wisely but you do have to start off realizing that you are working with a very heavy quad.You could buy a good used DS for about 3000 and spend another 3000 in mods and really have a reliable duner that makes a very good showing at the drag hill.If you want a DS that will always make a respectable showing at the drag hill and that will walk all over a piped and jetted banshee you can get that done for 2500 for sure.If you are expecting to always be the first to the top of the hill with a DS and 2500 in mods you will be disappointed for sure.
Old Nov 29, 2006 | 01:28 AM
  #29
cynick's Avatar
Thats why we figured mine when all is said and done to be about 4k OUCH. and thats if everything goes smooth, Wish me luck.
Old Nov 29, 2006 | 01:33 AM
  #30
MrMeaner's Avatar
Im not sure about that list but you can get a fast DS for 2500 in mods. Some things can be found used in really good shape. After all I dont think anyone really ever stops trying new things or has any idea of what they will end up spending. Its an sickness
