Gearing question.
Old Feb 1, 2007 | 09:25 PM
1882's Avatar
Runs a Full 730 Race Build!
Default Gearing question.
I'm going to do a 520 conversion and was thinking about 15/35 as compared to 17/40, my rationale being that the 15/35 combo would be even lighter as they are both smaller sprokets, does this sound logical to y'all? Do ya think the 15/35 gearing would feel any different as it is only the equivalent of one tooth difference?
Old Feb 1, 2007 | 10:34 PM
Atvmutt's Avatar
You must be running a Honda sprocket hub to be able to run that small of a sprocket???
Old Feb 1, 2007 | 11:15 PM
1882's Avatar
Actually I'm running HPR's aluminum hub which is the same as the factory unit except for being lighter aluminum, I see various vendors listing 35 tooth rear sprokets for the DS, had you heard that using that small of a sproket would require a different hub?
Old Feb 2, 2007 | 02:31 AM
RLarryCSwinger's Avatar
I to thought 38 was the smallest that would fit on a DS hub. I sure wouldn't bet the farm on it though. I will be curious to see if a 35 will fit.
bigred20653
Oct 2, 2015 10:05 AM
patrick.oc123
Sep 16, 2015 03:45 AM
bigbear350quad
Sep 11, 2015 12:40 PM
Bigtwin700
Sep 9, 2015 09:32 AM
awer1968
Sep 8, 2015 11:02 AM
