Lighting Question DS
If you are running the Baja lights you will be right at the system capabilities. The stock main is 65 and the Baja's are 30 I believe. The stator is rated for 290 watts but most of the info I have seen says you have about 240 watts to work with. I have run the 75's with the stock main but no Baja's. It worked just fine.
bzdok1234
30
02-23-2016 01:55 PM
