Head bolt torque DS 650
Old Feb 6, 2007 | 08:25 PM
enormous63's Avatar
Default Head bolt torque DS 650
I am new here but I have been reading all the topics published so far and I am building a 2001 DS 650 and I am in dire need of the Torque specs for the internal and external head bolts can anyone in here help? Thanks
Old Feb 6, 2007 | 10:55 PM
ScoobyDFW's Avatar
Welcome. I believe they are 24 ft-lbs for the outer 8mm bolts and 44 ft-lbs for the inner 10mm studs. Careful not to over torque the 8mm!
Old Feb 7, 2007 | 09:35 AM
enormous63's Avatar
Thanks I am sure there will be others.
Old Feb 7, 2007 | 11:21 AM
DSengineer's Avatar
Has been here a long time!
Those torque specs are correct, but I could have swore my stud bolts were 12mm and the outers were 10mm......
Old Feb 7, 2007 | 11:28 AM
ScoobyDFW's Avatar
8mm and 10mm refers to the thread size not the socket size.
Old Feb 7, 2007 | 11:59 AM
RLarryCSwinger's Avatar
The socket size is 15mm and 10mm. The service manual says exactly what Scooby told you. For about $50 you can replace the OEM studs with hardened ones and buy brand new nuts. (talking about the 4 main hold downs)
44 ft lbs is huge! Most of the race shops I know don't torque that far because it isn't necessary........even on high compression. If the threads on the nuts have any stress, they will pop at about 40 lbs. I start with replacing the studs, once you do that you should never have to do that again. That is a one time purchase for insurance. I always keep some brand new nuts around and I never put the old ones back on. I torque the small bolts to 20 ft lbs and the main stays to 39 ft lbs. The allen bolts on the timing chain side I just tighten past snug a bit by feel.
This is all done with a Cometic multi-layer steel gasket. I follow the torque sequence religiously and this has always worked well for me.
Good luck!
Old Feb 13, 2007 | 07:42 PM
enormous63's Avatar
thanks guys i got my parts and put it all back together, all together with the bike i have 800.00 in so i cant wait to ride. i appreciate the comments on here they all helped my greatly.
fordfaithful21
Dec 7, 2015 05:52 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
