04 X front shock setup
Old Mar 20, 2007 | 07:41 PM
worker10's Avatar
Default 04 X front shock setup
I've read the posts on how to setup the front shocks, and from what I understand you set them up with 2-3" of sag with the rider on the bike. In trying to set mine up like this the springs are almost as long as they can be, and when I push down on the front of the bike it has only about three inches of travel before it bottoms out. To me this seems to be too soft, but when I tighten up the springs the bike doesn't sag with me on it. My weight is 250# so I don't think that's the issue. Also on body of the shock towards the top is a allen headed adjustment screw, is that to adjust the valving?
Old Mar 20, 2007 | 07:44 PM
amd's Avatar
amd
Those shocks are kinda funny. Try setting them by jacking up the bike and take all the slack out with the nut. By slack I mean just run the nut down so the spring wont move around when the front end comes up. Don't tighten the nut so far down that you need a wrench to do it. Just snug it up to the spring while the front of the bike is jacked up and the front wheels are in the air. Give that a try and see what you think.
Also that screw is so you can refill them if needed. Those shocks are rebuildable.
Old Mar 20, 2007 | 08:52 PM
worker10's Avatar
I'll probably give that a try tomorrow. Thank you
Bratman2
Aug 6, 2022 01:42 AM
07Redrider400
Jul 25, 2015 05:31 PM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
