Lifetime Oil Filter
Old 12-21-2000, 07:18 PM
CALDS650's Avatar
Just order a stainless steel oil filters that filters down to 35 microns. Paper filter average only 50 to 80 microns. It is cleanable and reusable Just $65.00. It has a high flow rate even when the oil is cold. http://www.americandirtbike.com/
Old 12-23-2000, 12:58 AM
1BEARMAN's Avatar
Calds650 let us know how this works out for you and about the fit and finish.Thanks
Bearman
Old 01-07-2001, 12:36 PM
CALDS650's Avatar
The filter is easy to instal and looks great.
Old 01-08-2001, 04:43 PM
eli54's Avatar
This stainless filter is great for the older models, but the new 2001 has a longer, larger filter, and a different filter is required.
Old 01-08-2001, 06:45 PM
CALDS650's Avatar
Just give the guys at ADB a call they can make one for the 2001 DS650
Old 01-09-2001, 01:33 PM
ERICsRAPTOR's Avatar
How is it holding up and filtering? Let me know when you change your oil.
Old 01-10-2001, 09:47 PM
chop's Avatar
is there some way to clean this filter? otherwise it seems like to me that if there is trash in the filter it would stay in the motor if its never cleaned.could you tell us a little more about it if you can? thanks.
Old 01-10-2001, 11:18 PM
CALDS650's Avatar
Simply remove; rinse in clean solvent and replace. You use the same steps that you use for cleaning a K&N air filter
cswiger
Polaris Side by Sides
12
10-05-2015 03:34 PM
Nosniborpapa
09-12-2015 05:54 PM
Steeldon
09-09-2015 09:38 AM
black798
09-09-2015 07:42 AM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
Quick Reply: Lifetime Oil Filter
