Problem with charging battery HELP!!!!!!!!!!!
Old Apr 17, 2007 | 01:38 AM
steve2432's Avatar
Default Problem with charging battery HELP!!!!!!!!!!!
I have a 2003 DS650 Baja. My problem is my charge. I get 12.44 volts when the quad is off. It never charges past 12.5 when the quad is running and sometimes when its running it drops a little and sometimes it rises a little but most of the time it stays the same. When the quad is off it will have a small draw but nothing to make the battery go dead. My main problem is when I start the quad, when I am riding and turn the quad off I will have about 3 times to start it or else I will not have enough juice to start it. From off its 12.4 volts but when I try to start it it goes down to 11.8 volts. I will try anything to find out why its not working right. thanks
Old Apr 17, 2007 | 01:51 AM
DSRIDER650X's Avatar
hey man,
do a search on my name and look at the one post that say "something weird" there are some suggestions in there. Sounds like regulator/rectifier, or ground, or stator, or solonoid, or something in the charging system problem...just like I am having. Trial and error....could be anything from the reg./rect. to the trigger coil. most likely a loose wire or bad reg/rect.! But hard to tell. you need to test everything with a multimeter basically...
do you have a copy of the owners manual? there is good info. in the electrical section in it! I just found that out today! thanks to eaglecollector!
sorry i couldn't be more help!
Bryan
Old Apr 27, 2007 | 02:42 AM
steve2432's Avatar
I found the problem, the bottom bolt for the starter was loose. Not the bolt, the nut under the positive cable that goes to the starter, thanks guys. or thanks dsrider
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
bikedad3
Jun 29, 2015 08:58 AM
Jbird4681
Jun 9, 2015 01:59 AM
