Outy 800 Transmission
Old Apr 24, 2007 | 12:00 AM
BVROCKS's Avatar
Default Outy 800 Transmission
Just bought an Outy 800 and have a question about the CVT transmission. Do all the Outys wind up a bit before moving forward? Love the machine but do not like the jerk at the start. Makes it tough to go slow when dodging trees on a tight path. The power of the Outy is like a Corvette on steroids.
Old Apr 24, 2007 | 12:53 AM
Dufrane's Avatar
yes yes yes ok here's what i know ......on the 500xt there are 4 weights in the cvt on the 800 there are 6. now it's almost like a stall converter in a dragster .. well a hot rod. ok . the point is , it's a bad bad boy. it took my dad awile(and afew small trees) in the tight areas to get it figured out. but you'll get it i'm sure . ride safe and ride proud. you got one of the top machines out there.
Old Apr 24, 2007 | 12:57 AM
Dufrane's Avatar
also if your going to play in the mud contact me. i'll show you an awsome set up on a snorkle kit
Old Apr 24, 2007 | 01:37 PM
BVROCKS's Avatar
Thanks Dufrane. Was hoping maybe there was an adjustment that could be made that would minimize the wind up before it took off.
Old Apr 25, 2007 | 02:06 AM
kas379's Avatar
I don't know about that, my Renegade is basically the same and while I hear it whining sometimes while I'm moving, it doesnt do it before the forward motion engages, pretty much takes of just by poking at the throttle.
Old Apr 25, 2007 | 11:44 AM
propolaris's Avatar
can-am should do a better job on the clutch. brp builds tough machines they can do better.
Old Apr 25, 2007 | 02:55 PM
kas379's Avatar
Mine got much better as it broke in.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
