DS450 EFI new web site!!
#173
Am I the only one stayin up to watch this thing???? dual cam 4 valve (aprilla i think he said?) rotax motor, biggest bore, biggest throttle bodies 46mm, biggest valves 38mm, dual sparkplugs. On the chart they had it looked like the 450r made more power bottom-mid range then on top the ds450 pulled ahead and then kept going while the 450r maxed out. But then again jeremy schell is saying its quicker out of the gate but he's being payed by can-am so who knows. Ewwwwwwww. It looks like somebody sat on the front plastic and then put the ugliest headlights possible on it. Looks too much like a ds250, but it moves thats for sure.
#174
Based on the data they gave us in comparison to the TRX450, at a 15% better power to weight ratio and 9% power advantage, that extrapelates to 333 lbs dry.
Not a very accurate way to get that number........I wish they would just tell us what it weighs and how much power it is making.
The throttle body and valve sizing is very promising. I realize they say the pipe is very low restriction but at the size of that TB and those valves, that bike will pick up a lot by getting rid of the air box and putting a good pipe on it with appropriate fuel mapping.
Did I understand correctly that an EFI controller is not necessary? That all you have to do is plug the laptop into the stock box and adjust the mapping to suit your modifications?
Interesting ride......
#175
Yeah, he said tuners dream so I hope you can tweak the maps. They compare it to a Honda for power so at 33hp stock + 9% is say 36hp? Really stock dyno tests are useless until it's filtered and exhausted with the maps adjusted accordingly.
The light axle might be the reason Jeremy is getting holeshots. Only 5 lbs less than the YFZ?
I wonder if you could transplant a cylinder and head off a Mille? Instant jump to 500cc and they have run 52 and 54mm throttle bodies.
#176
With the intro of this ds450 motor alone I think this is going to be a winner!!!!!!!!
Apprilla design- 2 plug head. Did you see the sizes of the intake and exhaust vavles??????
The cams are on a bridge like the 650 motor [img]i/expressions/face-icon-small-smile.gif[/img] AND IMO the intake port is a take off from the the sport bikes (NO angled down turn into combustion chamber) much better flow design........
It sounds like the EFI controller will be programable (No aftermarket purchase to dial er in) YES [img]i/expressions/face-icon-small-wink.gif[/img]
NICE I whana see one when they arrive...............
#177
I'll be watching this machine closely,could definitely see one in my future!!I can see a lot of potential in this machine,might have to part with the Sport 400.It would look good sitting next to the new FZ600!!!!!!!!!
#178
<div class="FTQUOTE"><begin quote>Originally posted by: mystereid
I wonder if you could transplant a cylinder and head off a Mille? Instant jump to 500cc and they have run 52 and 54mm throttle bodies.</end quote></div>
My thoughts exactly.
Kind of like the old FT500 Ascot jug on the ATC350X engine trick. Man, am I dating myself...
#179
<div class="FTQUOTE"><begin quote>Based on the data they gave us in comparison to the TRX450, at a 15% better power to weight ratio and 9% power advantage, that extrapelates to 333 lbs dry. </end quote></div>
The specs are up on can-am's website. It weighs 345lbs dry.
