DS650 Cams & Cam Bridge Clearence Fit??
#22
#23
Seems like this valve thing should be something simple???
As for Ice Cream. . . I have ONE Wife and MULTIPLE Favorite Ice Creams!
I've been enjoying the Strawberry Shortcake Ben and Jerry's in the small cup - perfect for camping trips. About a scoop and comes with a plastic spoon in the lid.
Starbucks - Jamoca-Almond-Fudge
Coldstone - Stawberry's Blonde
Haggen's - Strawberry Ice Cream - Chocolate is good too.
Schwan's - Apple Pie Alamode & Vanilla Cups
Shmee - THIS is serious business!!! [img]i/expressions/face-icon-small-wink.gif[/img]
#24
There was clearence on the buckets, when I put it in the bike. But the weird thing is that it happens with just the clearence test out of the bike. Take the cams place them in the bridge and hold together with your hand and check to see if free spin..... In this case there is not. However the stocker and 109s did.
#26
So it sounds like it has nothing to do with the lobes or lift. It sounds like the slot in the bridge where the journals go is too tight for the journals. Cam journals shouldn't vary in diameter. I would put calipers on those and compare the measurement to stockers.
#28
Not in that direction......that I can see. The bridge could wear bigger and the cam could wear smaller if top end lubrication was marginal but you would see other signs like grooves in the tops of the buckets and galling and discoloration in the bridge where the journals are supposed to seat.
It almost has to be the cam but calipers will tell for sure.
Scooter's Shop
23
10-22-2015 07:04 PM
