want to install more lights on my DS650 any tips
Old Oct 4, 2007 | 02:01 AM
TheStir's Avatar
Started riding ATVs in 1974!
Default want to install more lights on my DS650 any tips
mrclark, try your link, its does not go to lights.... Thats all ANNIHILATER was saying....
Old Oct 4, 2007 | 02:27 AM
DS650-1962's Avatar
TRY DOING AN hid KIT ON YOUR STOCK HEAD LAMP,WORKS REAL GOOD AND THEY ARE KIND OF CHEAp NOW DAYS!
Old Oct 4, 2007 | 04:14 AM
mrclark's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: DS650-1962
TRY DOING AN hid KIT ON YOUR STOCK HEAD LAMP,WORKS REAL GOOD AND THEY ARE KIND OF CHEAp NOW DAYS!</end quote></div>
can you recommend one
thanks
Old Oct 4, 2007 | 12:12 PM
jusrlax's Avatar
I bought my Baja kit online from Parker Yamaha. It is a BRP kit, with everything you need, including detailed instructions. Cost was around $120. As I recall, they just plug into the existing harness, no splicing required. The instructions call for the aluminum covers (the slotted pieces you see on a Baja) to be riveted together. I went to Home Depot and used some small nuts and bolts instead. Makes it easier to change bulbs when necessary. I know someone has posted a link to detailed instructions with pictures, I would do a search for "Baja Lights" on this forum and see if they come up.
Old Oct 4, 2007 | 05:12 PM
  #15
ds650atv's Avatar
Thanks DSEngineer, I will check out these bulbs.
Old Oct 4, 2007 | 11:13 PM
  #16
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
[img]i/expressions/beer.gif[/img] Stock ds, Get two 100 watt laser star lights, make a custom mount above the shock run a relay, and you will light up the sky. i run them for years no problem[img]i/expressions/moon.gif[/img]
Old Oct 5, 2007 | 02:34 AM
  #17
DS650-1962's Avatar
CRAIGSLIST.ORG
LA area has HID kits for any vehicle-complete kit $150.00 shipped!!
motoringmax is the site.
Real good units,have them on my Ducati,DS650,Silverado stock and driving lights.F350.
They are great is like riding on a Trophy truck!!
Old Oct 5, 2007 | 03:29 AM
  #18
MRDS650's Avatar
Canadian and Proud of it !!!
I have converted my 2000 to use a 2005 headlight set up with 2 bulbs. I also installed an extra set of lights - cheapy walmart specials - i think they were 50 bucks. I did put a set of piaa bulbs in the 2nd set of lights. I wired the 2nd set of lights right off the battery with a in line fuse and a switch. I have run the lights for a couple hours of ride time and have not had a problems.
You can see might light set up in my pics.
Old Oct 5, 2007 | 09:56 PM
  #19
mrclark's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: MRDS650
You can see might light set up in my pics.</end quote></div>
Has anyone else run the lights off the battery like MRDS650 it sounds fairly easy to do will this end up being a battery problem in the future even if you get some cheapo low power lights?
Old Oct 7, 2007 | 10:53 PM
  #20
Scubasteve00's Avatar
I feel your pain in the lighting department. I have an 03 and have upgraded to the newer lighting system and baja light kit. It has helped tremendously, but I am still not satisfied. I ride a lot of desert and I am looking for a better system. I know one of the members on this website had a great idea of mounting one hella HID offroad light in the stock headlight position. I am looking to do the same, but going with two and an easily removable light bracket. Not sure if anybody has done this or knows of any kits out there.
JohnnySplat
Aug 6, 2015 12:07 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Bratman2
Jul 23, 2015 12:36 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
