Direct mount filter?
Old Oct 19, 2007 | 10:25 PM
TheStir's Avatar
Started riding ATVs in 1974!
Default Direct mount filter?
Anyone know of a direct mount filter that fits without hitting the seat or frame?
I want to try one on my build, but it bothers me to have my filter rubbing.
Old Oct 19, 2007 | 10:39 PM
DragonDJ11's Avatar
What carb are you running Scott. We picked up a direct mount from RWR and I do not think it was hitting the seat. Only problem we had with it was that it is smaller then the stock replacement and felt we were losing air flow with it.
Old Oct 19, 2007 | 11:11 PM
SANDMAN430's Avatar
the uni is a filter that works for that, another way is to cut the plastic on the seat. the intake tube always seemed better to me seemed smoother.
Old Oct 20, 2007 | 01:34 AM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
I ran a built bike the other day with a direct mount and was impressed. They always rub a tad butlike mentioned you can find ways around it. I am thinking about making a 3-4 inch snorkle tube that points downward and I will test on dyno.
I run snorkles on the lectrons but some like the direct. I will dyno both ways. I personally think some motors and pipe combos with head different porting will respond different to different combos. Good luck.
Old Oct 20, 2007 | 02:54 AM
TheStir's Avatar
I'm running a RW TM45.. and I have a brand new K&N with outerwear that is the same part number that RW sells but it hits the bottom of the seat.
I was thinking about cutting the bottom of the seat, but was worried about its strength.
I have head many strong arguments for the tube, and I have a late model reinforced one, but with my mile build I have a real strong mid range, and after talking to TheBom I think a direct mount on the TM45 might move that hit up the RPM range a bit and in my case make it a smoother power band.
Anyway, its just one last thing to play since the motor is all done.
Scott
Old Oct 20, 2007 | 11:52 AM
SANDMAN430's Avatar
I ran the 45 and never had much luck with the direct mount, but then i didn't have a dyno to tune with. the tube helped get the low end bog to go away it was also very noticeable on the main jets. direct mount was a 140-145 main jet, with the tube it was 150-160.
ghost civic
Jan 15, 2020 07:43 AM
neo27ny
Aug 24, 2015 02:02 AM
readymixer169
Aug 21, 2015 10:05 AM
MNatv89
Aug 12, 2015 06:00 PM
MNatv89
Aug 10, 2015 02:20 PM
