ds 650
Old Oct 22, 2007 | 10:09 PM
p-dawg's Avatar
Default ds 650
hey just bought a 2007 ds650 wanted to know what actual hope power is ? also what should be the first go fast mod. to install ? also why is the rev limiter set so low compared to other sport atv...
Old Oct 22, 2007 | 10:30 PM
400CatDriver's Avatar
Default ds 650
The first accessory should probably be a Banshee. LOL
Actually, I have a DS and ended up buying a Banshee to go fast because it is so ridiculously expensive to hop up a DS to run.
Old Oct 22, 2007 | 10:55 PM
DuneRider650's Avatar
I ride a little here and there......
Default ds 650
airfilter and maybe airbox modifications, pipe, cdi box to fix the rev limiter, ported intake, higher compression piston, diff gearing, loose some weight such as skids front fenders, hand guards. Ds's get pretty good numbers and can up with pretty much everything else who has the same mods.
Old Oct 23, 2007 | 04:59 PM
learnem's Avatar
Default ds 650
<div class="FTQUOTE"><begin quote>Originally posted by: 400CatDriver
Actually, I have a DS and ended up buying a Banshee to go fast because it is so ridiculously expensive to hop up a DS to run.</end quote></div>
DON'T YOU HAVE A YAMACRAP TO GO WORK ON?
anyway. start with a K and n filter and run with the lid off, with a pipe....you can get a billet endcap that produces the same amount of hp that a full big gun pipe would..so you can do that
also. look up OMR carb mods...and do all those mods to your carb....then make sure you rejet your bike.
good luck
Old Oct 23, 2007 | 06:04 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Default ds 650
Definitely do the OMR mods. They're FREE! And like everyone else said, filter/end cap/air box lid/sprockets/weight, weight, and more weight.
Keep us posted on the progress and your results of each mod.
Old Oct 24, 2007 | 03:00 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Default ds 650
Congrats, the first mod is the correct gearing for the riding you plan to do.
Next would be the purchase of the correct main jet for the area you will spend the majority of your time at.
Old Oct 24, 2007 | 10:14 PM
SANDMAN430's Avatar
Default ds 650
i second the gearing. then ride for awhile you may not want to start with minor mods. piston and a set of cams and a pipe is nice.
