DS 650 HELP ASAP
Old Nov 30, 2007 | 01:29 AM
Ratrod1's Avatar
Default DS 650 HELP ASAP
Hey , I just bought a 2000 DS 650 for a sweet price. There is no manual with it and i need to know how to change the fluids for this weekend. Please help. Do i drain it from the sump or is there a plug on the bottom of the motor.. . . Its just been sitting for 2 years..... what else should i do besides change the fluids should i drain the gas tank as well
Old Nov 30, 2007 | 02:02 AM
RealtorRider's Avatar
Congratulations on your purchase
I purchased my 2000 ds650 a couple years ago...I'm no expert but do make sure you find the info you need to do it correctly
there is an oil reservoir under the headlight area and there is a screen that needs to be cleaned
the 2000 year oil filter is different (shorter) than later years
I'm Sure someone on here will help out soon..If not I'll grab my book (at a friends house with my DS) and scan a couple pages for you regarding this so I can e-mail them to you
I'll watch the thread to see if you get the expert help
Good luck and have fun!
Old Nov 30, 2007 | 10:15 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
If the bike has been sitting for a few years I would change the oil before I do anything. You need to drain the oil from the oil tank in the front of your bike and also take out the nipple next to the drain plug and clean the screen that is attached to it also you need to drain it from the bottom of the motor and change the oil filter then I would clean the carb and drain the gas tank and clean the pit **** valve and make sure it flows freely and install a in line fuel filter also before turning over the motor I would squirt a few shots of oil in the cylinder and leave the spark plug out and turn it over a few times. It might smoke for a few seconds when you start it but it is cheap insurance also when you put oil back into it fill the oil tank and then turn the motor over with the spark plug removed until you have oil pumping out of yor head oil galley it is a 10MM bolt on the side of your cylinder head you should get a book or have someone send you a pic of where it is at I dont have any. This will insure that you are getting oil to the top of your cylinder and that your oil pump is not cavitating. After you start the motor only run it for a few seconds and recheck your oil stick becouse the oil that was in the tank will now be pumped into the motor refill to the full mark and repeat a few times until your oil is full on your dipstick and your motor has run for a few minutes. Good Luck and I hope this helps.
Old Nov 30, 2007 | 06:01 PM
SANDMAN430's Avatar
looks like they got you covered have fun.
Old Dec 1, 2007 | 04:27 PM
Ratrod1's Avatar
Is regular 10w 30 ok to put in it
Old Dec 1, 2007 | 04:53 PM
I use 4 stroke oil
Old Dec 1, 2007 | 07:58 PM
cynick's Avatar
use 4 stroke bike oil, I use the Honda synthetic blend, the bike oils have special additives in them for the trans. HP4 w/out moly is what I use.
Old Dec 1, 2007 | 10:28 PM
Tpsycho's Avatar
Don't use any oil with aditives unless it is for a bike or it will make your clutch slip.
Old Dec 2, 2007 | 03:35 PM
BansheeGuy69's Avatar
if you are not sure about what people are saying and you dont want to mess up your bike just get it serviced at a bombardier store or someone who you know who has owned one for a while
slowgsxr97
Sep 8, 2015 07:33 PM
400H0
10
Aug 20, 2015 07:34 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
mitchxc700
Aug 10, 2015 09:26 PM
Daryl Devine
Technical and How-To Articles
Jun 8, 2015 08:59 AM
