2003 ds650 baja loss power
Old Dec 1, 2007 | 01:08 AM
ZZTOP's Avatar
Default 2003 ds650 baja loss power
hello
my ds was not the same power i take a ride in heavy snow and i put four snow tire on after the next day i feel like the bike was not the same power
ok one of two plug was bad i take off one plug wire the bike still running after take off another wire and still running
what the compression on this bike is stock a to z [img]i/expressions/face-icon-small-smile.gif[/img]
i not able to find any work shop manuel on the web
i check very fast and find little crack on boots between the carb and intake when air go in the idle was upper like normal [img]i/expressions/face-icon-small-blush.gif[/img]
or i suppose the carb was not clean or i reed on other post i have diafrag (rubber) on this carb [img]i/expressions/face-icon-small-blush.gif[/img]
thanks for your help
or is in my head was the problem hihihihihi
sorry for my bad english [img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 2, 2007 | 03:35 AM
SANDMAN430's Avatar
did you find anything else out
Old Dec 2, 2007 | 05:47 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
Are you sure it wasnt the heavy snow tires that made it lose power? I used to run a set of 22-11-9 strykers on the back of my DS. I could rip through pretty much any depth of snow but when it came to racing or anything, it was a slug. The stryker tire alone weighed more than a razr on a rim....
Old Dec 2, 2007 | 11:00 PM
ZZTOP's Avatar
I think that know his, I had razr 20-11-9 worse my 4snow its 22-11-9 on ITP alu. rims and i put new plugs and check the intake for leak, no leak detect
the adjustment for the wire after the handle gas was loose and the idle at cool was not the same
the trail is very ruff after the 10 cm off snow and slush was freeze after -15 and was another 20 cm is comming
was a park the bike for some time and take trail come better
tanks all for your help
Old Dec 4, 2007 | 04:44 AM
DuneRider650's Avatar
I ride a little here and there......
A 22 inch tire is going to gear you up allot and cause noticable power loss.....even if the 4snow tire is light and on light rims you are going to have to gear down to a 15 tooth front sprocket. Take the top off the carb and make sure the needle is all together right...ive seen a couple come apart and they still run but have severe power loss. The colder it gets the more your jetting is going to change....it was -15 or so when i took mine out the other day and i had to rejet.
greg74
Sep 10, 2019 03:03 PM
mtdewmn
Jan 19, 2017 12:13 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
sweaver
11
Aug 18, 2015 03:47 PM
Chocobamofo
Jul 10, 2015 07:46 PM
