looking for someone to lighten ds650 flywheel!
Old Dec 22, 2007 | 07:15 PM
  #21
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Default looking for someone to lighten ds650 flywheel!
I have some flywheels, cut and uncut in my shop. I'll check them this week and see all the different weights.
Old Dec 22, 2007 | 07:50 PM
  #22
SANDMAN430's Avatar
that would be great
Old Dec 22, 2007 | 09:48 PM
  #23
TheStir's Avatar
Started riding ATVs in 1974!
I think the one you did for me Jeff was 15oz.
Old Dec 22, 2007 | 10:24 PM
  #24
mystereid's Avatar
It's official, I've been duning for over 30 years.
How does drastic lightening effect the charging system?
Old Dec 23, 2007 | 10:42 PM
  #25
derbyking's Avatar
i just did one,i got about a pound off the hub and roughly 1/2 lb off the flywheel itself
i doubt 2.5lbs VERY much unless the magnet got the heave hoe,the big steel hub weights about 2.5lbs itself and the flywheel is around 3lbs all stock
Old Dec 24, 2007 | 10:52 AM
  #26
THEBOM's Avatar
Flywheel?? are you meaning the big starter sprag gear that is in the back of the flywheel hub???
The 04 and newer are already lighter , with holes. These don't spin when the motor is running.
Old Dec 24, 2007 | 12:10 PM
  #27
derbyking's Avatar
no i mean the hub the flywheel bolts to,this is a 1st year motor though
Old Dec 26, 2007 | 03:05 PM
  #28
THEBOM's Avatar
Stock Flywheel hub (bolts to crank) 2lbs 4oz
Lightened 1lb 6oz
pick up magnet 2lbs 15.5oz
(It looks like you may take
some off the out side??? but
you lose the zero balancing holes
and weakens the metal band out
side the magnet)
Starter flywheel gear 1lb 2.5oz
(This does not rotate when
the motor is running)
Old Dec 27, 2007 | 02:23 AM
  #29
derbyking's Avatar
those numbers look just like what we got.
Old Jul 11, 2011 | 08:26 AM
  #30
infantryvet's Avatar
any more updates on flywheel lightening?I mean any more new info?thinkin bout'dis
