Getting her Built
Old Jan 2, 2008 | 06:12 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
Default Getting her Built
Im 100% postive that im gonna get my motor built in a month or two but cannot decide on what to do. I was gonna go with a RWR Stage 2, but after reading a post saying HPR is selling 730 kits for 1299 how can i resist?
Im thinking of a 730, A1A2 cams, Lectron 48mm, 520 chain.
The problem is i do not know what length of swingarm to get?
This will be drag racing and i will be running 4-sno tires i cant decide between a +4 or +6 what will be better, any input will be greatly appreciated.
Old Jan 2, 2008 | 06:19 PM
SANDMAN430's Avatar
+4 swing arm. stay with the builder cams
Old Jan 3, 2008 | 08:40 AM
DS650powe's Avatar
what do you mean by builder cams?
Old Jan 3, 2008 | 10:36 AM
SANDMAN430's Avatar
if you use eric for his cylinder and piston, then use his cams or the cams he recommends. mixing and matching sometimes causes problems. that way they can prepare you for any head work that you may want to do plus the compression of the piston and valve clearance
Old Jan 3, 2008 | 04:41 PM
DS650powe's Avatar
good point, i just figured i'd save a few bucks (like 400) by going with a1a2's
Old Jan 3, 2008 | 07:09 PM
SANDMAN430's Avatar
those cams might be fine, just ask another cam is the web 109's they should save you some money. they rev a little better than the a-1 a-2 woods
Old Jan 3, 2008 | 08:22 PM
ERBEDS650's Avatar
OR you can call Web and talk to them, they can help you build your own design for what you want out of the motor Bottom end Mid Top End, same cost as the 109s heck they were so great to work with and price wise had 2 sets of cams made.
Old Jan 3, 2008 | 09:08 PM
SANDMAN430's Avatar
what is the max lift on a cam before the springs coil bind? the other thing is valve clearance, that will factor in with the builders piston.
EIF
Apr 20, 2017 07:15 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
CosmoM
Sep 21, 2015 04:57 PM
