TIRE UNSEATS
Old Jan 27, 2008 | 09:24 PM
nastykitty's Avatar
Default TIRE UNSEATS
I HAVE 29.5 X 10 OUTLAWS ON MY OUTLANDER 800 AND EVERY TIME AFTER A MUD RIDE ONE MY OUTLAWS GOES DOWN. IF YOU FILL IT WITH AIR IT JUST WEEPS MUD,WATER,ETC. AROUND THE RIM. THE RIMS NOT BENT AND IM TIRED OF CLEANING THE INSDE LIP AFTER EVERY RIDE. WHAT CAN I USE TO MAKE IT SEAT WELL AND RESOLVE THIS PROBLEM??????????
Old Jan 28, 2008 | 02:20 AM
MRDS650's Avatar
Canadian and Proud of it !!!
My suggestion would be to take it too a tire shop, or remove it from the rim yourself and clean it properly. By properly i mean a small wire wheel to buff it real good, same for the rim. then clean both with pre-buff. Put tire together with as little lube as possible - if a tire shop is doing it they should have mounting paste, you can use very little to get the job done. Once the tire is on the rim load both the rim and tire with bead sealer (thick black stuff), then inflat the tire and you should have no more problems.
I own and manage a tire shop and have been doing it this way for a few years with no problems.
Old Jan 28, 2008 | 02:34 PM
nastykitty's Avatar
THANKS FOR HELPING ME OUT. I WILL DO THIS AS SOON AS I GET OFF WORK. I APPRECIATE YOUR HELP.
Old Jan 28, 2008 | 07:56 PM
QWODER's Avatar
Cleaning the bead and the rim and putting dish washing liquid generously around the bead before you air it up will work.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
