Ds 650 headlight voltage?
Old Feb 24, 2008 | 05:12 PM
dsmasterzach's Avatar
Default Ds 650 headlight voltage?
I recently had the newer style headlight put on my 01 and it was great. I also had two walmart brand lights on the front of my shrouds. about a month ago I turned on my bike and flipped the lights on and it blew a fuse. After i replaced it, it did it again and again. I checked wires and the lights and wound up re wiring all of it but it still blew the fuses. I replaced the walmart lights with new ones and still had the same thing happen so i took em off. Then my bulbs burnt out (of natural causes) so I replaced them with the silverstar headlights you put in cars and it worked for a while but now it will only push them on low beam, high beam blows the fuse. Does the ds not have a 12v system or is something wrong?
Old Feb 24, 2008 | 11:20 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Dude your going to make me sound like a parakeet here clean all your grounds make new ones if needed the 01 can easily run a slew of lights.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 25, 2008 | 05:07 PM
MRDS650's Avatar
Canadian and Proud of it !!!
I have the same setup on my 2000. I have the newer style headlight that i run 2 Piaa bulbs in and a set of aftermarket lights mounted to the rad shrouds that i run a set of 55 watt Piaa bulbs in with no problem. Although the set of aftermarket lights are wired to the battery directly with a seperate switch.
Joe454
Nov 20, 2020 01:19 PM
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Whitelx1
Oct 2, 2015 10:55 PM
PrairieDog126
Sep 16, 2015 01:33 PM
