i need a rev limiter cdi box what one should i buy? ds650
Old Mar 19, 2008 | 11:28 PM
  #21
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Default i need a rev limiter cdi box what one should i buy? ds650
To be honest Drgon the ds will go well past 8500 with the stock vavle springs. On the big girl the yellow nitro bike which it was a pami 760 on nitro and run stock springs forever.And laid a whoppin on all commers for several years. beat only by jeffrivercity .when i had it freshend up by the preacher he insisted on shim under bucket or he would not build it so i gave in.
Old Mar 19, 2008 | 11:49 PM
  #22
TheStir's Avatar
Started riding ATVs in 1974!
<div class="FTQUOTE"><begin quote>Originally posted by: DS650powe
whats the max rpms allowed by the big gun? i can pull 9k in 5th with it, and if i miss a shift and it revs i DO NOT HIT A REV LIMITER. im pretty sure the big gun has no rev limiter.</end quote></div>
My Big Gun for my 2000 had a rev limiter, I would bounce on it sometimes.
Old Mar 20, 2008 | 02:56 PM
  #23
boomer8201's Avatar
I havnt installed it yet, but I'm goin with the big gun because the price isn't bad at all and I don't need a crazy timing curve...yet!
Speed is addicting!!! and I'm not talkin bout pills!!
Old Mar 20, 2008 | 03:24 PM
  #24
DragonDJ11's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: boomer8201
Speed is addicting!!! and I'm not talkin bout pills!!</end quote></div>
That is an understatement. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 20, 2008 | 08:26 PM
  #25
Sport400inOH's Avatar
I received and just installed mine. I adjusted the needle clip down 1 notch to position 3 (as recommended by OMR).
HOLY SCHNIKES!!!!!!!!![img]i/expressions/face-icon-small-happy.gif[/img]
That really woke the bomb up!!!!!
The big gun made a very big difference...immediately! Took me about 20 minutes to put it in and adjust the needle. Much more mid range power and it revs out until it should be shifted (PULLS MUCH BETTER). I'm not sure how well it would work without the K&N and Dynojet, but it made the most difference BY FAR!
Old Mar 21, 2008 | 11:45 AM
  #26
boomer8201's Avatar
im still waiting to experiment, i wanna see what rejetting and exhaust endcap did for me so far, then i'll put the box on. i'm already in 3rd groove and took it for a test ride, just like you said sport!!! so i know once the biggun is in I'm gonna have to go take care of a tent problem, LOL
Old Jan 4, 2009 | 01:17 PM
  #27
jfar's Avatar
I just got the big gun on my bike. I haven't messed with the needle at all. Is that recommended? I'm racing with two buddies at the Parker 250 next week and I want to make sure we are set up properly. Since I put the big gun on there seems to be a minor "miss" in the engine - you can't come into a slow down without continuing to gas it or it will die. Any thoughts?
Old Jan 5, 2009 | 12:21 AM
  #28
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
First- Pull out a sparkplug and see what color the porcelan is.
If light tan - OK If completely white. Go up one jet size.
Second - When you are in third gear(3000rpm) and hit the throttle - Does it accelerate or a slight bog. If slight bog, check your needle height - 4th from top works bests for most - for stock needle. 3rd for DJ
Third- Turn pilot screw out 4 turns from all the way end. 3 turns if you have a DJ kit.
OMR
Old Jan 5, 2009 | 12:29 AM
  #29
cynick's Avatar
If it were me and I was doin it all over, just get the Vortex rev box, I put one on my DS and never had any issues at all.
Old Jan 5, 2009 | 12:38 AM
  #30
jfar's Avatar
Wow, thanks for the quick responses. Tomorrow and Tues are the days to fine tune. OMR, I will be giving it a shake out on Tues - i'll check for a bog or no bog. My partner riders have over 15 years on big bikes, currently YZ450's, and Banshee's. This is their first time on the DS and the smiles tell it all. Tuning it with your info will be easy for them. I'll try to do the forum "proud" without killing myself or (more importantly) my DS!
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
