motor guru's, advice please
Old Apr 18, 2008 | 01:05 PM
DSengineer's Avatar
Has been here a long time!
Default motor guru's, advice please
You are definately running too much octane. Pump premium 91-92 octance is all you should need.
Old Apr 18, 2008 | 01:30 PM
DragonDJ11's Avatar
Not sure on the pump gas. Where did you get that JE Piston man..... You may want to check and verify that you are really at 11.5-1 compression and not 12 or 13ish...
Old Apr 18, 2008 | 01:51 PM
DSengineer's Avatar
Well if he truly is 11.5:1 there should be no need to run race gas, but yes he should check what his true compression is. I recall hearing some of the earlier JE pistons were higher than advertised. At a minimum I would try going 50:50 mix and see if it runs any better.
Old Apr 18, 2008 | 03:24 PM
DragonDJ11's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: DSengineer
Well if he truly is 11.5:1 there should be no need to run race gas, but yes he should check what his true compression is. I recall hearing some of the earlier JE pistons were higher than advertised. At a minimum I would try going 50:50 mix and see if it runs any better.</end quote></div>
I can agree with that. I know Scott was having some problems with one he picked up a few months back, due to it being a higher compression so that was my basis.
So yep, back off on the Octane and see what that does for ya. You will most likely be jetting up for the lower Octane. More fuel=more power!!!
Old Apr 18, 2008 | 05:08 PM
  #15
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
DONT RUN PUMP GAS WITH 11.5 JE PISTON IF YOU DO = BIG MESS IN MOTOR
i found that out the hard way, it was acutally 12-13 compression and i blew my bike to ****.
Kaleb_00
Jun 1, 2016 09:15 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
ghost civic
Jul 15, 2015 10:48 PM
Scottma518
Jul 10, 2015 12:42 AM
