DS650X SHIFTING PROBLEMS
Old May 2, 2008 | 03:03 PM
Cessna's Avatar
Default DS650X SHIFTING PROBLEMS
My 06 ds650 x gets stuck in gear. The shifter moves up and down but is not engaging. After a few bumps it will shift again. Usually gets stuck in fifth but occasionally will not go from second to third without much persistance. It looks like a total teardown to repair. Any similiar experiences?
Old May 2, 2008 | 04:40 PM
DragonDJ11's Avatar
That sounds like it may be the shift fork being your problem. And yes, you would have a major project there. Got to split the cases.... But you can get your tranny gears backcut, and fly wheel lightened while you are in there..... Good things to have done...
Old May 2, 2008 | 04:41 PM
jusrlax's Avatar
Do a search on "shift fork" "shifting problems" or "popping out of gear". This has been an occasional problem with the DS 650, but usually on 00 01 02 and some 03's. After that, they supposedly upgraded the shift forks. Expensive to fix if this is what your problem is, as the cases have to be split. There is a guy on here, Hightower I believe, that did a very good step by step with pictures on how to do the shift fork replacement, if you are so inclined. Are you sure your clutch is adjusted correctly, and that its not slipping?
Old May 2, 2008 | 09:29 PM
TN01DS650's Avatar
It definately sounds like shift forks but could possibly be a bad engagement dog on your second gear.
I just finished replacing mine since I had it out of the bike already even though they didn't need it. It wasn't a hard job but you need some special tools (flywheel puller and a torque wrench to put it back together) and an open mind. I had some problems with the spacers on the transmission shafts when I put everything back together but no big problems. I believe Bombardier updated the forks in 2003.
I have my shift forks and shafts on eBay right now. You might be able to pick them up for a deal. My new ones cost $170 for everything. Let me know if I can help. [img]i/expressions/beer.gif[/img]
Old May 3, 2008 | 09:10 PM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
it may also be the shift shaft. its all in there to gether. bike bandit had all the parts and were pretty cheep too. shipping was within a week or so.
Old May 10, 2008 | 09:47 PM
Cessna's Avatar
Thanks to all. Will start wrenching next week.
Old May 13, 2008 | 01:28 AM
Cessna's Avatar
O.K. Got it down to the Magneto. Neew the Magneto puller p/n 529-035-748 and crankshaft protector p/n 420 876 557. Where can I find them for sale?
Old May 13, 2008 | 02:03 AM
cynick's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Cessna
O.K. Got it down to the Magneto. Neew the Magneto puller p/n 529-035-748 and crankshaft protector p/n 420 876 557. Where can I find them for sale?</end quote></div>
Motion Pro used to sell them, thats where I got mine, don't know if they still do but try em.
Old May 13, 2008 | 12:50 PM
Cessna's Avatar
Thanks again, love this forum! Ordered the tools from Motion Pro and parts from bike bandit today.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
