Red light
Old Jul 7, 2008 | 01:41 AM
Swaie's Avatar
Default Red light
I have a 2000 ds650 and I wanted to know if there is a way to test to see if the red light will come on, like a self test or something like that. I thought that it would at least come on when you turn the bike on, like a self test or something. Every since I got this bike I never seen the light.
Old Jul 7, 2008 | 01:46 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Default Red light
It comes on when you turn the key on, goes out after oil pressure builds up. Will come on when the bike gets too hot or when the pressure drops too low.
Old Jul 7, 2008 | 01:48 AM
FatHolly's Avatar
Default Red light
The light should come on when the key is in the run position/engine off (no oil pressure)... after staring and it runs for a few seconds it builds oil pressure and the light should go off. If this is not happening you may have a bad oil pressure sensor or maybe just a bad connection under the dash. Check the connection and if thats not it then replace oil pressure sensor.
Old Jul 7, 2008 | 02:45 PM
Swaie's Avatar
Default Red light
Can anybody tell me were the oil pressure sensor is.
Old Jul 7, 2008 | 03:25 PM
jusrlax's Avatar
Default Red light
Rear portion of the motor in the center. Has a wire coming from the top of it. May or may not have a little black protective boot around it. When you get this sensor wet, it has a tendency to short out, making the red light stay on.
Old Jul 7, 2008 | 11:55 PM
aceisback's Avatar
Military Rider
Default Red light
What jurslax said. While your back there go ahead and clean it with some good contact cleaner, hit it with some compressed air, then RTV around the boot and the base to keep anymore moisture out.
Old Jul 8, 2008 | 02:32 AM
DS650ryder's Avatar
Default Red light
i keep 3-4 of those sensors in muh tool box >.<
Old Jul 9, 2008 | 09:52 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
Default Red light
ditch the sensor & go to a mechanical gauge and you WILL always know if there is a problem. idio lights are just that. just my 2 cents. i replaced 3 of the sensors on my 05 and was tired of waiting for them to get here so switched with no more troubles.
Old Jul 9, 2008 | 08:43 PM
DS650ryder's Avatar
Default Red light
yeah i ran both for a while, put a T fitting on the case so i could have both light and gauge but rolled over and crushed the gauge = [
Old Jul 10, 2008 | 12:54 AM
Swaie's Avatar
Default Red light
If I wanted to install a mechanical guage, how do install it and what should the pressure? Is there a certain guage to get?
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
