What to do next...for low$$ and good HP
<div class="FTQUOTE"><begin quote>Originally posted by: bassetboy55
note if throttle stiffness is an issue the the lectron might not be the best idea. do your research cause if not done right you may regret the carb. you get.</end quote></div>
I've never heard of any throttle stiffness with a Mr.Horsepower Lectron so BananaHands don't worry about that. TM45's have a stiffer throttle but there are ways around that too as well so don't listen to that nonsense. The power gained is worth a little stiffness anyway, just ask any DS guy that has done it. [img]i/expressions/face-icon-small-happy.gif[/img]
Thottle stiffness is not a problem with a lectron as long as you have a good cable and it routed proberly.
I had Motion Pro make me a cable this year and my throttle is like butter now !!!
#15
Stay with Bolt on items
Ported Intake and a 45/46 carb, 520 chain and sprocket conversion, take the front and rear hubs and get them lighten, check flea bay hunt down some .160 wall Black label rims, a lighter fly wheel helps too. all these will add some performance and acceleration without getting inside the motor.
