Lectron off idle stumble/miss & won't idle.
Old 12-29-2008, 04:11 PM
1882's Avatar
Runs a Full 730 Race Build!
Default Lectron off idle stumble/miss & won't idle.
Man I still can't wrap my mind around how much the rod affects wide open throttle. I mean when the slide is all the way open the rod disappears, I would think the power jet takes over from there, ya sure about all this?
Old 12-29-2008, 04:33 PM
thebigshow's Avatar
I put mine on a dyno to tune it.... for my setup, the richer i made it on the bottem the more overall horsepower it made. I know your supposed to be in the area of 14 on your air to fuel ratio, but mine pulled more h.p when it was in the 12 to 13 range . My power curve would start out very rich (12) and lean out as the power curve came up(13.88).
Old 12-29-2008, 04:43 PM
thebigshow's Avatar
1882, i was under the impression ( i could be wrong here) but your need should never 100% leave the carb for fears of being stuck open, your needle should never be shorter than 1.969 or longer than 2.106. The needle should play a role in wide open, but it is a very small role.
Old 12-29-2008, 09:32 PM
1882's Avatar
Hey thanks and nice avatar by the way, go Big Ben!
  #15
Old 12-31-2008, 09:31 PM
thebigshow's Avatar
u bet!!!! i hope he get back for the playoffs!!!!!
wrencher82
09-30-2015 04:27 AM
IMLN
09-28-2015 03:32 PM
2many2ride
09-27-2015 04:35 AM
wrencher82
09-24-2015 03:39 PM
XxS0ccerstarxX
09-22-2015 02:40 PM
Quick Reply: Lectron off idle stumble/miss & won't idle.
