Help with DS650 Bogging
Old Feb 7, 2001 | 11:48 PM
ScoobyDFW's Avatar
I installed the dynojet kit along with the 2001 carb spring and 2001 longer main jet splash guard. I am running a K&N filter directly off of the carb. I am having some bogging problems under hard acceleration and when shifting into the next gear. Could it be that eliminating the airbox robs some lowend power/throttle response? Could it be that the airflow to the filter directly off of the carb is more resticted than the filter in the airbox due to the filters smaller size, the seat being in contact with the filter, and the frame and wiring around the filter?
Old Feb 8, 2001 | 12:12 AM
Majorecho's Avatar
I noticed a significant increases in low end torque as soon as I added the clamp on K&N and rejetted. Prior to the intake mod I couldn't wheelie w/o a little help from the clutch, now I can pick the front end up on demand over whoops and off dropoffs. I think the stock air box and snorkel were quite restrictive.
My original complaint w/ the DS was bogging over bumpy terrain, is this when you are seeing it? or are you experiancing bogging on flat ground at gear changes as well?
My fix was easy , float bowl was not adjusted properly and the fuel supply was inconsistent.Were you having problems before you put the extension splash guard around the main jet?
Also I saw a significant improvement in throttle response w/ the new needle. It revs flawlessly and very responsively.
Old Feb 9, 2001 | 09:28 AM
ds650parts's Avatar
sounds like it may need to be a bit richer
Old Feb 9, 2001 | 10:21 AM
turtle's Avatar
Hi ScoobyDFW, could you tell me if you know if there is any other comp. making a stage two kit for the DS, I already have a stage one from Wood with the Graydon pipe and want a little more hp.
Thank you for your help.
Turtle
Old Feb 9, 2001 | 12:31 PM
Jimmie's Avatar
team pami makes 3 kits
Old Feb 9, 2001 | 01:08 PM
turtle's Avatar
Hey Jimmie
Do you have any URL adress by any chance of Team Pami.
Thank's
Old Feb 9, 2001 | 01:27 PM
CALDS650's Avatar
here it is http://www.team-pami.de/ENGLISCH/
Old Feb 9, 2001 | 02:11 PM
Jimmie's Avatar
i want the ds760 kit
Old Feb 16, 2003 | 12:51 PM
DSJOBBER's Avatar
Default Help with DS650 Bogging
This weekend I experienced this same problem. I started with a Dynojet 185 and rejetted up to a 195. It really didnt help the problem at all. I couldnt hold 3rd gear up comp hill at Dumont to save my life. Most embarassing was perhaps the stock DS that beat me. Im led to believe that it is a jetting issue. On the flats it ran ok and there was no hesitation or shuddering. It just seemed like it had no nuts when trying top pull third gear. I was running Geckos so if anything I should have been spinning and not bogging the motor from excessive traction. Any help appriciated.
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
