Help with tire size
Old Mar 12, 2009 | 11:07 AM
Chumly75's Avatar
Default Help with tire size
Hey guys need some help from you busa and gixxer guys. Just purchased a predator that has frame stretched 11 inches, the swing arm is stock and a Busa motor. It only came with paddles and as I live in the middle of MO,not a lot of dunes, what size rear dirt tires should I be thinking about. I do not want to go smaller than 22, but can't decide if I want to put 25 on it. My riding will be mostly open trails, I'll stick to the ds for anything tight. Thanks
Old Mar 12, 2009 | 02:14 PM
DragonDJ11's Avatar
With a Busa in it, I would not go smaller then 25s. Any smaller and all you are doing is wasting RPMs
Old Mar 16, 2009 | 07:02 PM
justme23005's Avatar
Personally, I would run 22's & gear it higher. I get nervous when the sidewalls flex under acceleration & the back end bounces side to side.
Bratman2
Aug 6, 2022 01:42 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
rcappie4
Jul 18, 2015 07:51 AM
