help with ds650x
Old Apr 15, 2009 | 01:48 PM
andyds650's Avatar
Default help with ds650x
hi
got a 05 ds650x k&n filter lid off 185 main jet yosh exhuast 40 rear 15 front sprocket procom cdi box will only wheelie in first gear no other gear dose about 85 flat out there is just no bottom end dose anyone no why could it be the rev box had carb cleaned out and set up had compresion test down its about 175 so ok there plus nice brown plugs
please help thanks
Old Apr 16, 2009 | 11:20 AM
NickDS650's Avatar
what does it sound like? does it miss or backfire or drag / lag anywhere on the throttle? put the air box lid on and try that to see what the diff is. Does the quad act ok from all points of RPM's? (watching the tach)
Old Apr 16, 2009 | 11:28 AM
DragonDJ11's Avatar
If you are still stock carb, they really like the lid on. Try the OMR stock carb mods, that will most likely help. Also, if you are a "bigger" rider you may need to lower the gearing some more
dirtynewguy
CAN-AM (BRP) Ask an Expert!
Sep 15, 2014 02:47 PM
dirtynewguy
Jul 31, 2014 01:23 PM
DarrinW
Jun 30, 2012 11:52 PM
Lesotho
Feb 28, 2012 07:17 AM
DuneRider650
Jan 15, 2007 02:31 AM
