Dead Battery - will it ever hold a charge again?
Old Apr 30, 2009 | 07:45 AM
check's Avatar
Never make a decision before you have to, always have a Plan B, and don't tell me it's not possible!
Originally Posted by Sport400inOH
Shoot, then I guess all of my small batteries are destroyed then. If that is the case, then why can I keep starting my powersports toys? I have a basic Yuasa battery in my Zx1100 Ninja - 4 years old (have had it go completely dead 3 times). I have a Murrays special in my Polaris Sport 400 - 3 Years Old (Has gone dead with a load on it twice from not disconnecting a snow plow lift). My Ds650 has a Walmart battery (Almost 2 years old) has gone completely dead twice. I also have a Walmart battery (barely bigger than a lantern battery) in my kids' Chinese 90 (Has gone dead once and is 8 months old).
I have charged all of these at a 10 amp rate. None of them have gotten more than warm. The 90 battery is the only one that I do not leave charging for an extended period of time.
Having a rather extensive background in remote control, it is typically accepted that 1C (1xCapacity) is a universally acceptable charge rate for almost any battery type (Even the tempermental Lithium Polymer batteries). Seeing how the typical capacity of a Battery for the DS650 is 13 Amp/Hours, it would be perfectly safe to charge it at 13 amps. The Outlander in question most likely has even a larger battery with greater capacity as it is a Utility Quad and therefore charging it at 10amps would pose absolutely no threat.
The reason for higher amperage and voltage charging is to break up any sulfation crystals that may have formed and turn them back into lead sulfate. If the crystals have not gotten too large, this process can indeed "bring back" a dead battery.
Well, after all is said and done it seems that my battery may be OK after all. I charged it over night for about 20 hours or so, on a 1 amp charger. Just now I took the charger off and the voltage was 13.17 volts. Will check it again in a few hours to see if it is still up there, and then I should do a load test of some sort.
Old Apr 30, 2009 | 08:05 AM
TLC's Avatar
TLC
I left my lights on my ATV on at camp over night the next morning the battery was stone dead, I gave it one pull of the pull start and let the motor idle for 10-15 min and the ATV's electric start was fine from then on.
Old Apr 30, 2009 | 08:35 AM
KQ400Pilot's Avatar
[QUOTE=Sport400inOH;2785040]Shoot, then I guess all of my small batteries are destroyed then. If that is the case, then why can I keep starting my powersports toys? I have a basic Yuasa battery in my Zx1100 Ninja - 4 years old (have had it go completely dead 3 times). I have a Murrays special in my Polaris Sport 400 - 3 Years Old (Has gone dead with a load on it twice from not disconnecting a snow plow lift). My Ds650 has a Walmart battery (Almost 2 years old) has gone completely dead twice. I also have a Walmart battery (barely bigger than a lantern battery) in my kids' Chinese 90 (Has gone dead once and is 8 months old).
Using your high amp charge rate, I see that all of your batteries keep going dead.
Thank-you for proving my point.
Old Apr 30, 2009 | 11:43 AM
Sport400inOH's Avatar
Boy have I really got it wrong...I always thought that charging a battery increased its electrical potential. Thanks for clearing that up for me.
I also must have it wrong that a lead-acid battery will self-discharge at a rate as high as 40% per month. There must also be no such thing as a parasitic load from various electrical components. My bad.
I bow to your supreme knowledge and experience on batteries and electrical theory (How could I not with all of the proof, clarification and facts that you have provided?).
Thanks for setting me straight.
Old Apr 30, 2009 | 05:09 PM
  #15
check's Avatar
Default Battery holding
It's 6 P.M. now, some 9 hours after I disconnected the 1 amp charger, and the battery has self-drained down from 13.17 volts to 12.79 - still enough to do the job. No load test yet, however.
Old May 1, 2009 | 02:55 PM
  #16
FYI, here is a battery voltage & specific gravity (as measured by a hydrometer) to state of charge chart:
SOC= State of Charge
SG = Specific Gravity
V=Voltage
SOC SG V
100% 1.265 12.7
75% 1.225 12.4
50% 1.190 12.2
25% 1.155 12.0
Discharged 1.120 11.9
Battery sulfation can start as soon as the specific gravity reaches 1.225 (or voltage reaches 12.4v).
Get a load on that battery and cycle it (run it down a bit using a hefty load, then charge it back up) a few times as soon as you can!
Old May 1, 2009 | 08:09 PM
  #17
upnort's Avatar
I would say that you are probably good to go. About 12.5-12.6 is resting voltage.
Old May 7, 2009 | 02:37 PM
  #18
check's Avatar
Default Battery seems to have survived
Well, the battery still shows about 12.79 volts, so I guess I dodged a bullet. Will load and recharge it a couple of times just to be sure, though. Thanks for the great help folks!
Old May 1, 2018 | 04:14 AM
  #19
kaceyoneil's Avatar
There’s a new way called EZbattery (www.EZbattery.info) to bring nearly any type of old battery back to life so it’s just like new again. This method works with nearly every type of battery out there ...and it’s simple and quick. In case you’re wondering, you’ll be able to bring car, phone, and laptop batteries back to life with this. It even works with solar/off-grid, marine, golf cart, and forklift batteries. Plus, many more!
slowgsxr97
Mar 18, 2022 03:40 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
ScopeZ_
Jul 28, 2015 01:44 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
