ds 650 head torque
Old May 4, 2009 | 08:03 PM
plater1's Avatar
Question ds 650 head torque
wondering if anyone could give me the torque spec 4 an 03 ds 650 cylinder head any help greatly appreciated thanks
Old May 8, 2009 | 09:55 PM
BioWare's Avatar
Toxic Ryder
You will get a better response in here the guys in here know alot when it comes to this sort of things.
Old May 11, 2009 | 10:55 AM
DSengineer's Avatar
Has been here a long time!
37 ft/lbs - main stays
20 ft/lbs - outer waterjacket bolts
Use a good torque wrench and go around alternate bolts in a criss-cross fashion. Do not overtighten! Pay special attention to the waterjacket bolt closest to the timing chain as it is a common spot for failure. It tends to backout when you tighten the small hex screws on the outside of the cylinder. Make sure you go back and check it after tightening the outer hex screws
Old May 11, 2009 | 10:59 AM
DSengineer's Avatar
Also make sure all the studs are coated in oil before you start to torque down. Those torque specs are based on them being oiled. Not a bad idea to replace all the nuts with new ones while your at it. Eric (OMW Racing) can set you up with some good replacements.
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
