Electrical question...quick one
Old Jun 8, 2009 | 09:29 AM
chirochris's Avatar
Default Electrical question...quick one
How can i tell if i am running straight off battery and not off charging system like its suppose to...
Old Jun 8, 2009 | 10:36 AM
yellowdemon23's Avatar
In a car you can disconnect the battery after it is running and the alternator will keep it running. If it dies then you know you are running off of battery power cause the alternator won't keep it running. As for the DS I'm not sure if you can do that because the DS seems to be so dependent on the battery.
Old Jun 8, 2009 | 04:23 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
With the key off check your battery with a multimeter. Should read around 12 volts. Key on, hit start, voltage should drop to around 9.5v. After the motor is running voltage at the battery should hold steady around 14.25.
Hope this helps...
Old Jun 9, 2009 | 11:40 AM
chirochris's Avatar
Will that tell me if im running directly off battery or if charging system is working
Old Jun 9, 2009 | 11:53 AM
if you were running off of battery alone there wouldn't be a way for the battery to go from 12V to 14.25V if it wasn't charging.
Old Jun 9, 2009 | 04:21 PM
aceisback's Avatar
Military Rider
Ditto. If you were running on battery alone you would see it drain and not recharge. The 14.25 is the system operating as it should.
Old Jun 9, 2009 | 04:48 PM
chirochris's Avatar
Oh..so if i start it and let it run for a while and the volts drop and drop then its running off bat...
Side note.....lost my aux lights also...wtf
Old Jun 9, 2009 | 09:59 PM
aceisback's Avatar
Military Rider
Yes, and eventually it won't rise enough after sitting awhile to even restart your bike. It will just stay drained. Are all of your fuses good, and your grounds good? Connections tight? Anything aftermarket tied into the elec system?
Old Jun 10, 2009 | 08:58 AM
chirochris's Avatar
No extras tied in...sanded all grounds down(powder coat)...gonna recheck fuses...
Old Jun 10, 2009 | 12:28 PM
justme23005's Avatar
Probably a bad regulator/rectifier assembly
