Electrical question...quick one
#15
![Cool](https://atvconnection.com/forums/images/icons/icon6.gif)
All you need to do is start the engine and while the engine is running carefuly disconect the positive batery terminal ( be sure not to touch it to ant metalic Parts ) if the engine stops running then the atv is running off the batery ie: the charging system has a fault or failed.
Good luck
Good luck
#18
Check stator pick up assembly, my bike was shutting down, and then starting up as if it's trying to buck me, I thought it was CDI, But mechanic at Power Toys, narrowed it down to "Stator pick up assembly". $125.00 plus there Labor fee's. Every bike problem is diffrent, but I'm just putting in an Idea that may be an aquation.
Sw00p
09-24-2015 02:50 PM
