new ds owner with a fan question
i recently got a 2006 DS650X. it runs great and i love it. i have not yet taken it on a ride because i want to make sure everything is in working order. i have putted around the house and let it idle for a while, but the fan has yet to come on. how long would it have to idle, from startup, before the fan will come on? that way i could check it. i am dying to take it out but dont want to destroy the engine.
Just idiling with you giving it a few revs every now and then will take atleast five minutes. It will kick on at 210 and off at 190. I've ridin in triple digits out here inthe desert through some tough sandy washes and hill climbs and it still takes a while to come on. I was concerned as you are at first but once I learned the machine found it was normal.
Ride hard, ride safe.
An easy way to check if its working is to unhook the 2 wires at the fan switch (by the thermosate) and jump the switch. As soon as you connect the 2 terminals the fan should turn on.
I keep a toogle switch with a couple of short pieces of wire with me, when I ride. Just in case
Logan Collins
09-05-2015 08:03 PM
cdstang
08-31-2015 07:52 AM
