2007 DS650 will not crank !!!
Old Jul 3, 2009 | 10:19 AM
dailyDSproblems's Avatar
Default 2007 DS650 will not crank !!!
ok, so i have this DS650 and i have bought a new battery, spark plugs (NGK DR8EA) ,and had a valve job done
i rode it for 2 hours and it started spitting and sputtering, and all power went out, no headlights, neutral, or red light....nothing
and i really need to find a wiring diagram or fuse position diagram so i can run the right fuses and stuff......i replaced the fuses under the seat with 15's for now......if anyone has the manual and could scan it in for me!! i cant find it anywhere and i cannot afford an Ebay manual right now haha.
Old Jul 3, 2009 | 11:24 AM
DuneRider650's Avatar
I ride a little here and there......
Do you still have your old battery??? if so i would put it back on and see if that fixed the problem i went through allot of odyssey battery's and it started spitting and sputtering when they went out also went through a stock one and it did the same....maybe you just got a bad one...also check the relay underneath the seat right behind the battery it should be attached to the air box check all the wires that can cause you to loose power. Sounds like a bad battery to me....
Old Jul 3, 2009 | 12:33 PM
i have my stock battery, but it is no good
and the relay has 3 yellow wires, a black one and one red
which ones are important and if i need a new relay where could i find one cheap?
and i also need to know what fuses to run under the seat, im running both of them on 15's but i dont know if that is right or not
thankyou, the help is MUCH appreciated
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
