Lectron idle tuning question
Old Sep 2, 2009 | 10:00 PM
1882's Avatar
Runs a Full 730 Race Build!
Default Lectron idle tuning question
Does the needle position have any effect on idle quality? I can't seem to obtain a quality idle on my 730 build and am not sure what that one screw seems to do on the Lectron 48 dual power jet carb, not the idle adjustment screw. Any suggestions?
Old Sep 3, 2009 | 11:00 AM
mbarryracing's Avatar
What screw? The screw on the power jet?
Old Sep 3, 2009 | 01:58 PM
1882's Avatar
Well there are two screws that are covers for the power jets and then there is another brass screw between the idle screw and choke. It is the same size & type as the idle screw, the are both spring loaded. The idle screw is vertical and this one is horizontal.
Old Sep 3, 2009 | 02:19 PM
Sorry then. Not sure as I haven't ever seen one of those on the Lectron that I'm familiar with before. The two in the power jets control their fuel flow to those when they actually flow fuel at WOT only.
Maybe that brass screw is an choke fuel adjustment? I didn't think that lectrons had pilot (slow jet) circuits that would have that as an air / idle mixture screw like other brand carbs.
The Lectron design only has the main needle and bore?
Old Sep 3, 2009 | 02:54 PM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
The idle screw is the horizontal one - the vertical one is an air-bypass adjustment screw. Yes, the needle adjusts the idle quality (rich/lean) the bypass screw allows more air to enter the carb at idle if turned out & the transversse if turned in (less air). Its purpose is to fine tune the idle circuit.
Old Sep 3, 2009 | 07:31 PM
1882's Avatar
Ahhhh I see, I'll have to play with it to see what she does, thanks!
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
Kyle5050
Dec 13, 2019 04:25 AM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
