Problems with Graydon Exhaust System ?
Old Feb 27, 2001 | 06:36 PM
JNBOMB650's Avatar
Hi, I am about to install the Graydon exhaust system on my DS but am a little worried with a couple of problems posted on this forum.
Can you tell me about any problems you have had with it ?
Thanks!
JNBOMB650
Old Feb 27, 2001 | 08:04 PM
clif's Avatar
The only problem that I have had was small leak at the two into one conection.It's no big deal,but be sure to use the high heat silicone to seal it.Also I used the rubber spacer mounts from the stock pipe. But the pipe kick a##. Have fun!!!!!
Old Feb 27, 2001 | 08:43 PM
jeffnrivercity's Avatar
clif, did you get instructions with your pipe?? I didn't Also didn't get any with the graydon steering dampner,I called them they said they don't send them, told me to look in the feb issue dirtwheels(ds/raptor article) to see how to mount the dampner.I figured it out before I found the issue but mine's not mounted like the one in the article,but it works seen others mounted just like mine.More direction would be nice from graydon
Old Feb 27, 2001 | 09:54 PM
BlackHawk's Avatar
I guess that would be one advantage to the PEP steering damper, it comes with directions. Though, no one checked for typo's on it... It lists the model as: Bombardier DR650. The directions look O.K. they did some rough drawings and even a couple of actual measurements - enough to figure it out anyhow.
Old Feb 28, 2001 | 01:11 AM
bkutina's Avatar
hey my pipe didnt come close to fitting right. they told me to not use the rubber mounts. i didnt get directions. i sent the whole thing back and they are sending another one. my ds has been out of commision for 3 months now waiting on there ***'s. also they did not send any silicone to seal it even though they tell you to use it.
Old Feb 28, 2001 | 07:01 AM
JNBOMB650's Avatar
Now I am really worried ! Is there any good things about it ?
Which one is the best: Graydon or Ron Woods ?
JNBOMB650
Old Feb 28, 2001 | 08:23 AM
clif's Avatar
No,I did not get directions with my pipe.They should send directions on the pipe and they also should send the silicone for it,free.I had to call,and order the stuff for $7,and they have a $30 minimum.But over all,I am pleased with it(performance-looks).I have been hearing real bad things about Big Gun pipes,like pipes not fitting and sealing up,and making a rattling sound.But Graydon should send directions on instaling their pipes,and provide all the necessary stuff with it. Just my two cents......
Old Feb 28, 2001 | 11:18 AM
Jimmie's Avatar
i have stage1 and the woods pipe is great not one problem.
Old Feb 28, 2001 | 02:59 PM
JNBOMB650's Avatar
Does anyone have ron woods web address ?
Thanks
JNBOMB650
Old Feb 28, 2001 | 03:26 PM
As far as I know he doesn't have web-site He did tell me that I would get better performance if I used his pipe with my stage 2 kit instead of the Graydon pipe that I am using now, or should I say the graydon pipe that I am waiting for that I sent back to get fixed!!!!anybody wanna trade a Wood's pipe for a Graydon?
skinnyr6
Aug 25, 2023 02:18 AM
Mojave250A
Jul 11, 2015 10:38 AM
rcappie4
Jul 10, 2015 04:54 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
